![]() Join Date: Sep 2001
valve body in 700r4 - no spring?
Ok, so my 700r4 is stuck in first and the govenor is fine, also TV cable is set and working correctly. So I dropped the valve body hoping to find some trash in a valve or something. Found no trash but did find this:
One of the valves (see pic - the one boxed in blue) does not pring back into its closed position when I slide it open. All of the other valves do. Could this be my problem, and if so how do I fix it? |
Lovin' Life in Miss.!
NFC. Just wanna see the answer too.
I cant help either but sure am glad to see that pic. I was wondering what I would find if I dropped the valve body. Mine is working better now but takes off in 3rd or 4th unless I slightly tap the gas peddle when taking off.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Looking in my Haynes manual "10360" GM sutomatic transmission overhaul on page 8D-22 it shows a valve body on the 700 R4and says that if you take a small screwdriver or pick and pry against any of the valves they should snap back to the closed position.
In the troubleshooting section, it says under -will not shift out of first- 1/2 valve stuck in the valve body. There should be a small pin holding each valve in place. If you drift it out the valve should come out. You may have a weak spring or a burr causing the valve to stick. Hope this helps.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. Last edited by VetteVet; 08-24-2005 at 10:23 PM. |
The valve you have in question is the TCC valve. Go up three and you have the 1-2 valve train. Just curious but what is that red stuff you have holding the checkball?
98 Neon 97 Grand Prix GT 02 Grand Prix 40th Anniv. 86 GMC 5.0 77 Olds 98 6.6 REAL AMERICANS, DRIVE AMERICAN |
#6 | |
Vett Vett,
You seem like you know your stuff. I have a 700r and on ocasion when cold under light acceleration the 2nd to 3rd shift misses pops out of gear and if you let off the gas then lightly tap the gas it will pop into 3rd. Only happnes when cold. What could be causing that ? Thanks for the help
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Yeh I should have written it out, it stands for Torque Convertor Clutch. But you still didn't tell me what that red stuff holding your checkball is
Not wanting to hijack this thread but can anybody help with my problem? It does not downshift after coming to a stop. A light tap on the gas and it takes off normal. Without the tap of the gas it takes off in 3rd or 4th, I dont know which.
Are you certain it's in 3rd or 4th, probably 2nd. Does it work fine after that?
And I'm still waiting for Guyryan to tell me what's holding that checkball ![]()
98 Neon 97 Grand Prix GT 02 Grand Prix 40th Anniv. 86 GMC 5.0 77 Olds 98 6.6 REAL AMERICANS, DRIVE AMERICAN Last edited by 86k10; 08-26-2005 at 12:22 AM. |
#11 | |
Msgt USAF Ret
700 r4 stuff
From what I read about your shifting problem the book lists several probable causes. It's like asking why is my engine missing. There are so many reasons that it will slip or not shift that it may take a teardown to find the culprit. Two that may cause the problem are govenor weights and springs and tv cable not adjusted correctly. There are several references to the clutches and that is why 86k 10 asked if it worked ok after it shifted into third. Jwil41 It sounds to me like you may have a sticking TV cable . The TV valve controls downshifts as well as upshifts. Take the cable off the carb and work it by hand and see if you feel any binding.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
I have had the cable disconnected several times and it works freely. I have looked at the govenor and it moves freely.
Also when I go to reverse from any forward gear it feels like it is "locked up" and the truck will not move. If I go to park then reverse it works ok. This happened after towing a truck 200 miles in the Texas heat with only an auxiliary cooler. I have no tank in radiator. I know, what a stupid thing to do. ![]()
#13 |
Oky I kinda figured that it's going to have to be removed and rebuilt angain. The tranny works fine thru all the gears just on occasion it cant find 3rd and then it bangs into 3rd and nicely into 4th.
I really dont want to remove the tranny. Oh well.
#14 |
the red stuff is probably trans assembly lube. it is actually auto trans fluid mixed with vaseline. it is used to lube the seals for installation and to retain the check balls during assembly.
#15 |
Wow - I though this thread was lost. Thanks for the replies so far. Yes, the red stuff is assembly gook. And quite handy in keeping those check balls off the garage floor. If that valve is the TCC valve, could it impact my 1-2 shift? (still awaiting tranny book from library). Interestingly, the valve that's marked in the pic above does not exist on the valve body of another 700r4 I checked....
Here's a fluid diagram I found on the chevelles site - not exactly applicable but for those searching for info, maybe this will help. http://img200.imageshack.us/my.php?i...icdiag25iv.jpg |
#16 |
Well I talked to two tranny guys today - took my valve body to two shops to ask their ideas. Tranny guy 1, an older guy, told me that this valve was deleted in the design around 1984 (my tranny is '86) and that the always-open valve was a normal result. He said he thought my stuck-in-first problem was something deeper in the tranny.
Tranny guy #2, the rastafarian, said that rebuilders often leave the spring out of that valve to create harder shifts and that it was no problem, but that I was missing 2 check ball valves - one in that jelly-bean shaped spot on the top left corner of the pic above and one off the pic on the right. He seemed sure that these two check balls were my problem and that I should bolt it up and be done with it. Would have been nice if the old guy and the rastafarian saw it the same way... anybody ever leave out the check ball and find themselves stuck in first? |
#17 |
Any vehicle that had an ecm didn't have that valve in it which started in 86 but the bore for the valve was still there it was just filled by 2 aluminum plugs and they did that until the 90 model year when they deleted the bore as well. Which is nice because you can take a later trans and install the valve train in there and it will function without an ecm just like the older ones. The TCC valve has nothing to do with anything but controlling the TCC lockup. It reacts off of TV pressure and tells it when to lock and unlock depending on throttle position. It has nothing to do with the shift patterns at all and yes you should have a total of 3 checkballs on the valvebody itself.
98 Neon 97 Grand Prix GT 02 Grand Prix 40th Anniv. 86 GMC 5.0 77 Olds 98 6.6 REAL AMERICANS, DRIVE AMERICAN Last edited by 86k10; 08-29-2005 at 10:41 PM. |
#18 |
Msgt USAF Ret
more 700r4 stuff
I found this website where a guy tells about rebuilding the 700 and a lot of other stuff. Check the FAQS and read what he says. It might give you a clue on yours. You have me at a disadvantage, What's a rastafarian?
http://www.technicalevolution.com/faq.htm
