Old 08-22-2005, 06:36 PM   #1
TN70C10
rear end id
I know ive seen it on here a hundred times but cant find what im looking for. I have a 12 bolt with the #s on the right side of the chunk when you look at it from the back. Its the only # I could find on the outside it reads
67890
12345
the ring gear has these #s 3817778 11:41 gm 5-70 1
I was able to determine that its a 373 but was wondering if this is the Eaton or Dana or what. What does the 5-70 1 mean? Thanks.
TN70C10 is offline   Reply With Quote
Old 08-22-2005, 07:30 PM   #2
Blazer1970
Blazer1970's Avatar
It is a GM corporate 12 bolt. It is not an "Eaton" or a Dana axle. 5-70 is a date code, I would assume May, 1970.
Blazer1970 is offline   Reply With Quote
Old 08-22-2005, 07:54 PM   #3
acloco
With 3.73:1 ratio...of course!
acloco is offline   Reply With Quote
