Old 08-23-2005, 06:41 AM   #1
Sp00ks65
Opinions: 2-3" front drop, coils or drop spindles?
I'm new to the board. My son and I are working on my 65 lwb stepside. Right now we have the frame in the driveway degreasing. Soon we will start the suspension rebuild and I can't decide the best way to do the front drop.
I am looking for a later model chevy p/u to pull the front clip out of, among other parts. I have been unsuccessfull thus far but I'll find a one eventually. Basically we want to convert to front disks, auto column, ps, pb.
I have a 283 bored .060 over, mild cam, and am working on electronic ignition, 4 barrel carb. I also thought about some shorty headers and 2.5" exhaust out the back. I'm undecided on the headers.
Anyway, first things first. What are opinions on the best way to drop the front end? Drop springs or drop spindles? I want a driver that won't jar your teeth over bumps but handle a lot better than it did stock. I plan on sway bars etc.
Thanks.
Sp00ks65 is offline   Reply With Quote
Old 08-23-2005, 10:13 AM   #2
fchava
fchava's Avatar
spindles are always better than just springs. It allows you to retain the stock steering geometry and full spring travel so the ride should be unchanged from stock. I have put spindles on six of my vehicles and have been very pleased with the results.
fchava is offline   Reply With Quote
Old 08-23-2005, 12:31 PM   #3
Sp00ks65
Thank you for the reply. Those were my thoughts as well. I just thought I would get confirmation. I'm sure I'll have more questions as the project proceeds
Old 08-23-2005, 05:21 PM   #4
slammed64
get a front clip from a 73 to 87 i think, and use drop spindles for sure. what ever year you get for a front clip, ask for that year when you get spindles
64 chev 1/2 ton lwb fleet slammed
86 chev Z28 IROC camaro (vacation car)
73 VW super beetle (wife's project)
02 VW Golf 2.0L (good on gas car)
04 FORD F-350 CREW CAB diesel (work truck)
slammed64 is offline   Reply With Quote
Old 08-24-2005, 12:35 AM   #5
squizzleboy
it is a much better ride with drop spindle/ drop coil combo
63 chevy
350 crate
th350
silverado seats
american autowire harness
squizzleboy is offline   Reply With Quote
Old 08-24-2005, 08:08 PM   #6
Demmit_Hemmit's 65
Demmit_Hemmit's 65's Avatar
I Did The Drop Spindle Drop Coil Changeover And Improved My Ride And Handling 200%....................that's What I'd Recommend,,,,,,,,,,,,hemmit
Demmit_Hemmit's 65 is offline   Reply With Quote
Old 08-25-2005, 10:16 AM   #7
Sp00ks65
So you and hemmit did a combo spindle/coil drop. A couple of quick questions, how much was your total drop, what brand parts did you use and what was the ratio of of drop of spindle and spring.
Thanks for all the responses.
Old 08-25-2005, 12:59 PM   #8
SIR
SIR
SIR's Avatar
drop spindle & coils......
HOWDY...BRUCE HERE. I used 2 1/2 drop spindles and 1" drop springs in front and 4" drop coils in back from classic performance prouducts great prouducts great service ...you can see what they did for me at http://community.webshots.com/user/lvnr66
good luck....have fun..BRUCE..
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 08-25-2005, 08:31 PM   #9
Demmit_Hemmit's 65
I Also Went Through Ccp.............good Company To Deal With And Got My Parts To Me Right Away.....................mine Was Also 2 1/2" Drop Spindles With 2" Drop Coils In Front And The 4" Drop Coils In The Rear....................it Dropped The Front About 5" And The Rear 6"...............also Bought The Shocks To Work With That Combo................good Luck And Have Fun.................hemmit
Old 08-25-2005, 09:31 PM   #10
fchava
fchava's Avatar
I have the same setup and drop as Demmit also from CPP. Since u are using a later model front clip , I would also check with www.sporttruckdirect.com , I have bought 4 of the Western chassis drop kits from them. Very good support!!
Old 08-25-2005, 09:44 PM   #11
fchava
fchava's Avatar
just checking my picture
Old 08-26-2005, 02:39 PM   #12
slammed64
i used 3 inch spindles from belltech, and firestone air bags for rear. probably goinh to put in springs in the front too. bags eventually!! another thing to, is that i only paid about $200 canadian for my spindles, which is alot cheaper than cpp.
