08-23-2005, 10:43 AM | #1 |
can a starter have a "dead zone" in it?
Sometimes I'll turn the ignition key and nothing happens. Try it a couple more times and it hooks up and starts. Could the starter have a bad place or dead zone it it? Either that or bad ignition switch? Bad solenoid?
New batt, new alternator, wire connections to starter, etc are all great. |
08-23-2005, 11:28 AM | #2 |
I've heard of that before, starters can have dead spots, where you just bump it a bit then if fires right up. Eventualy it will need to be replaced, assuming thats it.
Hope that helps? |
08-23-2005, 11:49 AM | #3 |
did you get it from stevan king???
08-23-2005, 12:33 PM | #4 |
The next time you "hit the dead spot" at home, roll under there and look at the flywheel where the starter gear SHOULD engage it. A long time ago I had a th350's ring gear with a few not perfect teeth in one spot. When I shut the car off with the starter aligned to hit there, I had to rotate the tired old engine a bit by hand to get the starter to engage.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
08-23-2005, 12:44 PM | #5 |
I've dealt with the dead spots both from bad teeth on a flywheel and burnt spots on the starter relay windings.
08-23-2005, 12:52 PM | #6 |
Back in the sticks
During this time you say "nothing happens", is the starter turning at all? Mine does that, and its a bad solenoid, I'm just too lazy to replace it. If your's does nothing though, that sounds more like the ignition switch is going out. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
08-23-2005, 12:58 PM | #7 | |
Guess I need to do some testing to isolate the problem. Might be cheaper than diagnosis by parts replacement, which is what I usually do. |
08-23-2005, 04:35 PM | #8 |
the armature on your starter is burnt causing the dead spot. it will last for a while but will need to be replaced
04 GMC Sierra RCSS 70 CST LWB 04 HD Sportster 1200 Custom |
08-23-2005, 05:52 PM | #9 |
Worn out brushes can cause that too, next time it acts up, whack it with a hammer a few times, (backyard diagnostics), if that helps, it might be brushes. Really, you need to remove it and inspect it anyway if it's acting up, it's giving you fair warning now !!
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
08-23-2005, 06:20 PM | #10 |
Shaved
Maybe faulty neutral safety switch?
1969 |
08-23-2005, 07:05 PM | #11 |
Msgt USAF Ret
You can have a dead spot in the starter but that won't prevent the solenoid from engaging. If you don't hear it clicking then you aren't getting 12 volts to the "S" terminal on the solenoid or there is an open circuit in the solenoid. The next time this happens you should jump the solenoid with a remote starter switch and see if the starter turns or the solenoid clicks. What you need to do is isolate the problem and jumping the starter solenoid may tell you whether it's the solenoid or the power source to it. Make sure you have the coil wire pulled so it won't start or have it in neutral or Park with the emergency brake on.
If the starter turns then chances are it's the ignitiion switch or the neutral start switch. Have you jiggled the gearshift lever when this happened and did it help?
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
08-23-2005, 09:06 PM | #12 |
I'd say bad solenoid, with a small clicking but no RRrrr RRRrrr RRrrr. There is a big copper washer in there that makes contact and starts the starter motor. Over time the copper washer gets arc burns in it. If you are adveturous, or cheap like me, you can pull apart the solenoid and dress the washer down. Or, you can replace the solenoid, be sure to buy american here, as the cheap imports use a copper plated washer that goes bad fast. Napa sells a good quality solenoid, they also sell cheapies so ask about the different grades when you buy.
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
08-23-2005, 10:15 PM | #13 | ||
After reading your follow-up
If the hammer trick works, your starter is drawing too many amps. Of course a shop with a load/amp draw tester will be able to tell you that too.
08-24-2005, 11:00 AM | #14 | |
08-24-2005, 11:42 PM | #15 |
I have had a very similar problem also.
Occasionally it would be <turn key-nothing> <turn key-nothing> <turn key-nothing> <turn key - she starts> BUT, I know on that starter I had tried to re-use the solenoids copper disk that makes the contact and figured it was from that. I replaced the solenoid. It's "snappier" if that makes sense. Haven't driven the truck enough to say 100% that that was it though.
72 Chev C-10 90% restored (former AZ truck) ... 71 Chev K-20 Cheyenne my vacation crusier... 72 Chev C-10 Now retired and striped after many faithful miles... 72 GMC 1500 Retired to the junk yard after bought new in '71... |
08-25-2005, 01:47 AM | #16 | |
Designated A-hole!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
08-25-2005, 07:08 AM | #17 |
Mine was doing the exact same thing for about two years. I replaced the starter and it hasn't happened since.
------------------------------------- Tim '67 C/10, '04 Tahoe ------------------------------------- |
