Hood Stiffeners a Good Idea?
I saw a truck over the weekend with a bent hood and remembered that J.C. Whitney sells hood stiffeners for these trucks. I have a 1977 C10 and was wondering how big a problem bent hoods are, and if these hood stiffeners are a good idea. I hate to drill holes in the truck, but perhaps an ounce of prevention is worth a pound of cure.
Thanks for your response. |
yeller
I wouldn't run them, I would just make sure the hood hinges/springs are in good operational order. Bad hinge assembly maintenance is what causes hoods to kink.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#3 | |
Professional Grade
![]() Oil them every time you do an oil change, and you'll never have a problem
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Thanks for the quick reply. I like these suggestions and will splash a little oil on them right now. Thanks again.
What Hump?
This brings up a good question, what is everyone using for oil on hood & door hinges, 3 in 1 or some kind of grafite? I was told years ago by a locksmith never to use wd40 since it rusts up. I need to know since my 99 sub & tahoe are amking alot of noise.
tom
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
I have them on my hood (home made ones) because the same day I got my truck painted I went to close the hood and it bent right in half. I was pizzed to say the least.
#7 | |
Overcamber
yea i use new motor oil the same way...it lasts alot longer than penetrant sprays i find..they all seem too evaporate over a short time..just my 2 cents..
i'll never run them, i like my head too much. the creases in the hood are designed to prevent the hood fromt coming through the windshield in a hard front crash. because of crashing trucks as a hobby, i can tell you that they work great. a buddy of mine forgot to remove the stiffeners from the hood of one of the trucks he ran. thank god we ran 3 steel straps across the windshield, or it would have come through when it sheared the bolts off. instead it just slid up the straps and covered the windshield opening a little. every one i set up i actually grind the notches out a bit, and run no less than 6 strands of #9 fence wire across the windshield opening twisted as tight as i can get them.
#10 | |
. Years ago, I was looking to straighten and then stiffen my old '77 hood. I was made aware of this safety feature and decided against it...
#11 | |
#12 | |
Ditto. |
| Bookmarks |
