Old 08-23-2005, 07:48 PM   #1
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
Hey tranny gurus
I have a TH400. Have had it for a while. What are the electrical connections on the driver side? I have asked around town and recieved about 3 different answers. One told me it was electronic kickdown. One said it was to hook up reverse lights. and one said it was to control a lock up torque converter. Which one is right? If it is going to be something beneficial i want to hook it up. If not i am not too worried about it.
Current Rides:
Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread
EvilK5 - 71 K5 Blazer
Evil Twin - 2006 Suzuki M109R
EvilDmax- 2018 GMC 2500 Denali Duramax
chevyguy_72 is offline   Reply With Quote
Old 08-23-2005, 08:01 PM   #2
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
That terminal is for the electric kickdown, there was either a switch on the carb(67-70) or a switch on the accelerator pedal(71-72) that downshifted the transmission to the passing gear.(2nd) I don't think it has to be hooked up though.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 08-23-2005, 08:02 PM   #3
JimKshortstep4x4
Talking
It is for the electric kickdown detent switch. There should be a switch on your accelerator, inside, (71, 72's).
Jim
Old 08-23-2005, 08:04 PM   #4
cowboy33713
Howdy:
It is for the electric "passing gear" kickdown. The TH 350 used a cable activated kickdown. The 400 has an electric kickdown. On 67-69(?)trucks the switch for this was mounted near the carburator, where it would be pressed by the throttle arm when near full throttle (like when you wanted to pass someone now!). Later, it was mounted on the bracket for the accelerator pedal, under the dashboard (the usual set up after GM was using cable throttles in place of old fashioned rod linkage). There are a couple of suppliers who make a one size fits most type replacement for those of us in need of a way to make the T400 downshift using the throttle as GM had intended; I will likely buy the one that Lokar makes - almost too nice to hide under a truck.
cowboy33713
cowboy33713 is offline   Reply With Quote
Old 08-23-2005, 09:02 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The TH400 will actually go from 3rd to 2nd with the wire unplugged... it is for when you floor it and it needs to go to first gear...that's what it is for.
Old 08-23-2005, 10:09 PM   #6
chevyguy_72
Vintage Evil
does anyone have a picture of what the oem piece looks like?
Current Rides:
