08-23-2005, 09:02 PM | #1 |
Leafs to trailing arms
I would like to change my leaf spring 71 to trailing arms so i can run bags on the rear. Does anyone sell just the bracket that goes on the crossmember to support the front of the trailing arm? It looks to me like the crossmembers are the same, The leaf spring crosmember has holes for the brackets.
08-24-2005, 01:26 AM | #2 |
One of the few GMC'ers
im sure they are the same. im planing on doing same thing. most auto manifacturers use the same frame for all trucks 1/2 to 3/4 and maybe even 1 ton not sure though. its a price thing for them cheaper for them to use all the same frames just with different suspensions on them.
87' Silverado 4x4 "Young, Dumb And Full Of Cum" |
08-24-2005, 02:37 AM | #3 |
I doubt you're going to find anybody that sells new brackets. You can find trailing arm parts but mostly those are meant for cars that go around in a circle and usually have some adjustability. Some of the parts we can use. You can get adjustable brackets at SCP but you'll need two left hand sets. The reason they sell a right and a left is because the l/h have up/down adjustments and the r/h brackets are slotted for in/out. Having said all that take a look at their l/h brackets as I think you could definitely mod them to work and they are pretty cheap. A link might be nice, huh? Or whenever I get around to removing my cross member I will be selling it. But I have lowered the mounts one set of holes and welded them on per the Hot Rods to Hell kit. The reason I'm getting rid of it is I want more adjustment and got a ECE unit from Brothers to modify.
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
08-24-2005, 06:54 AM | #4 |
67 is sold
If you're going to bag the truck, checkout the custom brace setup from Early Classic
08-24-2005, 07:08 AM | #5 |
blood type; Retumbo
I did the same excact thing 3 years ago. I found a truck box trailer & robbed all the parts. the X members are the same. those brackets are there to spread the load. you may be OK by boxing the frame if you cant find the brackets.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
08-24-2005, 08:36 AM | #6 |
Thanks for the advice so far. I guess i wasnt real clear in my original post. the brackets im referring to are the locating mounts for the front of the trailing arms. The front bolt of the trailing arm goes through this bracket. I have trailing arms and a crossmember from a donor truck but I thought it would be easier to just add the brackets to my existing leaf spring crossmember rather than removing the whole crossmember from my truck and the donor truck.
08-24-2005, 09:44 AM | #7 | |
For what it's worth, I like the Early Classics c-member. It's definitely solid & well built.
08-24-2005, 11:23 AM | #8 | |
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates) 67 short step project (will get SWB from the 68) 67 Camaro, #'s matching (my wife's) 03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear Last edited by fade94; 08-24-2005 at 11:23 AM. |
08-24-2005, 01:20 PM | #9 |
crossmember needed
If he's not interested, I need that rear shock/frame reinforcement crossmember that's riveted @ the coil mount area. I've got everything else for my leaf to coil conversion, just missing that.
PM & let me know what you have . . ..... Thanks, Scot
08-25-2005, 11:42 AM | #10 |
Im in PA. I have everything i need, just a matter of moving it from one truck to the other. Looks like a lot of rivets to grind off. Thanks for all the help.
08-25-2005, 11:47 AM | #11 |
A good air chisel with about 150 psi behind it will pop the heads off in a jiffy. If necessary you can drill the rivet head out and then even a wimpy chisel can knock it off. Use the air chisel with a pointed chisel to drive em out.
Saskatoon, Saskatchewan Canada |
08-25-2005, 02:17 PM | #12 | |
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates) 67 short step project (will get SWB from the 68) 67 Camaro, #'s matching (my wife's) 03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear |
08-25-2005, 02:38 PM | #13 |
The parts are the same long or short. They're just located in different spots on the frame.
I need the crossmember only (for the shocks).
