Old 08-23-2005, 10:44 PM   #1
formulafire99
formulafire99's Avatar
Cool SM465 with np205
I have a SM465 trans. with a NP205 transfer case.What gear oil would you recommend putting in these and how much do you think it would take.
formulafire99 is offline   Reply With Quote
Old 08-23-2005, 11:11 PM   #2
72 CustomCamper
huh ???
72 CustomCamper's Avatar
80W90 and I think 5 quarts should do both...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 08-24-2005, 03:30 AM   #3
Americanrider
Remove the fill plug, pump in oil untill it runs out the fill plug hole, replace plug.
Americanrider is offline   Reply With Quote
Old 08-24-2005, 07:03 AM   #4
68C15
blood type; Retumbo
68C15's Avatar
if it gets colder than about 30* in the winter I suggest the synthetic gear oil from GM. I use to have the same combo in a 80 K20 & it was hard to shift in the winter before I switched. sorry, the excact name slips my memory right now.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 08-24-2005, 07:41 PM   #5
72 CustomCamper
huh ???
You can actually use ATF in them, but if the seals are bad it wont last long...
Chuck
