Old 08-24-2005, 09:17 AM   #1
1969 modified
favor please
I also posted this in fuel guage reply. Could someone please disconnect their brown wire from the tank send unit at the special notched plug on the side of the fuse block and measure the voltage on the remaining male lug in the fuse block.
Also does anyone have the actual wiring diagram of the tank sending unit and the fuel guage. I'm trying to get it clear in my mind but having trouble. If I had the circuit drawn in my mind or paper I could troubleshoot it pretty quick. I'm not understanding why they run the brown wire from the tank sending unit directly to the fuse block, because I don't think the brown wire has 12 volts on it.
1969 modified is offline   Reply With Quote
Old 08-24-2005, 11:55 AM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
The principle is 12v goes onto gauge, then to sending unit, the sending unit is a varible resistor o-90 ohms to ground. as the fuel level changes the value of of ohms change,letting more or less current to ground, the gauge reads this voltage drop or gain.
sneakysnake is offline   Reply With Quote
Old 08-24-2005, 12:01 PM   #3
sneakysnake
not real clear, but a wiring diagram
http://www.geocities.com/chevroletc1070/wiringdias.html
Old 08-24-2005, 12:12 PM   #4
tomatocity
tomatocity's Avatar
E=IxR
I=Amps, E=Volts, R=Ohms
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 08-24-2005, 08:24 PM   #5
Big Block
Big Block
Big Block's Avatar
It's 9.6 volts if you put it to a 12 volt sorce you will smoke the sending unit. How do I know, because I did it accidentaly. I pluged it into the constant 12v on the fuse block. B.B.
Big Block is offline   Reply With Quote
Old 08-24-2005, 08:33 PM   #6
1969 modified
Thanks for the help. I located my problem and now the guage is working great. When my two sons were helping install the new seat and bolt hole locations, apparently the sending unit wire got pinched to ground underneath the seat support.
Thanks for everyones help.
