06-29-2002, 07:42 PM | #1 |
Stupid question
I feel stupid asking this, but I need to know. How on earth do you get the light switch rod out? I tried everything possible, and I don't want to just yank it hard and break something (experience tells me not to), the chassis manual is real helpful and says "remove it". I would appreciate any help. The reason I am taking it out is because I have no speedometer needle and was going to install one. The former owner unscrewed the speedo cable from behind and so I screwed it back in and it worked, it just chirped. So I did what he should have done, grease the cable. Works fine now, just no needle. Thanks
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
06-29-2002, 07:48 PM | #2 |
there's a button on top of the switch, work your hand up behind the dash and push the button down while pulling the knob out....
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
06-29-2002, 08:07 PM | #3 |
I found it but when I push down on it and pull out nothing happens, the lights just go on as usual. Do you have to push like really hard or what?
06-29-2002, 08:08 PM | #4 |
A lot of them you have to pull the lights into the parklight position (one click out) THEN push the button.
Good Luck. CoryM
1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada http://www.geocities.com/chevroletc1070 "Take up our quarrel with the foe: To you from failing hands we throw The torch; be yours to hold it high." Lieutenant Colonel John McCrae, Canadian Army |
06-29-2002, 08:13 PM | #5 |
Now I got it. Thank you both.
