08-24-2005, 12:20 PM | #1 |
Its Magically Delicious
vacuum fitting
im going to be converting over to power brakes .. im currently running a th350 .. so i've need a fitting that is shaped like a "T" to get vacuum to the tranny and the booster at the same time ... where should i pick this up and what size threads should i be looking for ??
thanks
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
08-24-2005, 12:29 PM | #2 |
The side that the booster runs off of should just be a simple barbed hose fitting that the booster line slips over and then clamped. Without seeing the tranny side line setup it's hard to answer that. A good place to start is a local hardward store.
08-24-2005, 12:42 PM | #3 |
You could pick up something like this.
Ricks camaro parts, paragon, and classic industries sell these. |
08-24-2005, 12:43 PM | #4 |
More Cowbell....
That is what I did (hardware store). I took my single port out of the intake and took it with me. Bought one that had two threaded ports in it (same size). I then bought two barbed hose fittings (as mentioned by Americanrider).....one for each size vac line needed. Voilla.....power brakes!
EDIT: while I was typing, the picture was posted above.....I like that better...gotta' check into one of those!!
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket Last edited by Putter; 08-24-2005 at 12:44 PM. |
08-24-2005, 01:50 PM | #5 |
An American Soldier
Putter, what are barbed hose fittings. I have to find something. I have a monstrosity with 3 ports (1 - xmsn, 1 small plugged, and 1 huge one with a bolt stuck in it). I need to get something that will work. I have a 1988 350 in my 69 SWB Step. I like the Power Brake Inlet Manifold Fitting that demi posted, but I can not find it at Classic Industries or Ricks. Also, I'm not sure of the threading on mine, sine the manifold is newer. Thanks.
Dan dan.brue@us.army.mil |
08-24-2005, 01:59 PM | #6 |
any autoparts store
08-24-2005, 02:13 PM | #7 |
Normally, your booster vacuum is pulled from the base of the carburetor at the rear. If you don't have power brakes, there should be a 1/4" pipe plug in the hole. Simply remove it and screw in a barbed hose fitting. The port in the intake manifold where the transmission vacuum line hooks up is normally 3/8" pipe thread, some aftermarket manifolds may be different.
72 Cheyenne SWB Fleet/original 402, TH400, buckets & console 65 C10, 350TBI, 700R4 (work in progress) |
08-24-2005, 02:19 PM | #8 |
72402.. are you referring to a q-jet ??
demi : thats exactly what im looking for.. thanks
08-24-2005, 02:39 PM | #9 | |
More Cowbell....
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket Last edited by Putter; 08-24-2005 at 02:42 PM. |
08-24-2005, 10:52 PM | #10 |
"Trucks with Class"
I've got a real one!
$15 shipped...if you want this one and don't have to chase all over trying to make something.
I just put one on an alum intake...see pics on here later on another post. |
08-25-2005, 12:37 AM | #11 |
What do you use to remove and install these fittings?
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. Last edited by tomatocity; 08-25-2005 at 12:38 AM. |
08-25-2005, 01:14 AM | #12 |
An American Soldier
PICKMUP...I got one out of a salvage yard today. Could not find it at AutoZone, Kragen, Parts Plus, or NAPA.
Demi...I still would like to have a new one. Can you send me the link to where you found that. I could not find it on any of those sites. Thanks.
08-25-2005, 03:51 PM | #13 |
Here is one place that has them.
ricks camaro parts I hope this helps. 4tiresngas - I sent you a pm. demi Last edited by demi; 08-25-2005 at 03:56 PM. |
