Old 08-24-2005, 02:05 PM   #1
71chevylongbed
Got Horsepower?
71chevylongbed's Avatar
increasing gas mileage
is it possible to detune a motor to get better fuel mileage. now that gas is over $2.50 a gallon for regular i no longer care about going fast
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit"
SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers
71chevylongbed is offline   Reply With Quote
Old 08-24-2005, 02:34 PM   #2
355
355's Avatar
My 69 lwb use to get 10 mpg going up hill, down hill, loaded, unloaded it made no difference. Now, at 80 mph I get just a little over 16 mpg and feel great about it. Rejetted the Performer, went too lean and had to come back some, one stage lower on primary and secondary. Edelbrock states that the Performer are factory jetted rich and may have to be custom jetted. Then the 700r4 WITH lock up. When the lockup went out I dropped about 1.5 to 2 mpg. Fixed that in a hurry. And finally got rid of the 373 gears and went to 307s. Still got alot of power to impress the youngsters but I do like delaying that right turn into the gas station.
1969 C10 Long Step,355,700r4w/lockup, HEI,Weiand,750 Performer,1.6 rockers,Camel Humps,Comp 262Extreme,Hedman,2 1/2"pipes, tele/tilt,SunRoof,ps,Disc pb,ac,Cragar,eaton,Corvette style roll pan, Bowtie louvered tail gate,lowered 2/2.
355 is offline   Reply With Quote
Old 08-24-2005, 03:36 PM   #3
71chevylongbed
Got Horsepower?
i had my motor dyno tuned for max power and they used a gas analyzer so i know that the way it is right now it isnt too rich.if i put in the smaller jets will i need to retard the timing. are there any adjustments that can be made with out rejetting to increase mileage?
Old 08-24-2005, 04:00 PM   #4
355
355's Avatar
Since they used a gas analyzer that option seems to be out. The next is the gearing and the type of transmission. If you read the post scripts our setups are very simular. What kind of mpg are you gettin now?
Old 08-24-2005, 05:58 PM   #5
acloco
Thought about a two barrel? They do atomize fuel a little better...but you have to have the right intake, ignition curve, etc.
For you...look into changing the curve on your distributor - both the mechanical and the vacuum advance.
acloco is offline   Reply With Quote
Old 08-24-2005, 08:26 PM   #6
see ten
WTB this ad
see ten's Avatar
You could always take the fan off the engine and go with an electric unit.
The amount of drag the fan creates really drags down the power. The fan alone is good for 2-3mpg. I started out with a stock motor that had been bored .030 to restore the compression. With this setup I was getting mid 9-10mpg. I then went from points to a Pertronix ignitor and re-gapped my plugs. This helped but only a minimal amount. I then pulled the stock intake and replaced it with an Edelbrock performer. Hell the valve covers were off so I went ahead and installed Comp Cams 1.52 roller tip rockers. At this point I saw no need to install the old distributor. It was replaced with an HEI unit with an MSD coil and wires. When I put the breather back on the carb I put a taller element in it so it could breathe a wee bit better. After all this I was getting a solid 12MPG. I then installed my electric fans at the same time I put on the Vintage Air and March Performance underdrive pulleys. My mileage the last time I checked it was 14.75. By the way this is real world driving in the left lane of the interstate, running the air. I don't ease around babying it just to see what kind of MPG I can get.
see ten is offline   Reply With Quote
Old 08-24-2005, 08:46 PM   #7
farside847
farside847's Avatar
Originally Posted by see ten
You could always take the fan off the engine and go with an electric unit. The amount of drag the fan creates really drags down the power. The fan alone is good for 2-3mpg.
WOW!
Is that a fan kit you used? Which one? 3MPG is worth $10 a tank to me!
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 08-24-2005, 10:06 PM   #8
see ten
WTB this ad
see ten's Avatar
Originally Posted by farside847
WOW!
It's a flex-a-lite 295 series. It is a universal fan but it is designed to be used on a radiator of the same core width as 67-72 chevy trucks. I built the upper bracket to bolt on to the factory upper shroud mounts. I modified some of the brackets that came with the kit to build the lower brackets. This is not a cheap fan but neither is gas. It will pay for itself if you drive your truck enough. I have the same fan on both my C10 and my K10. I also have a Flex-a-lite fan on our Jeep Wrangler.
Old 08-24-2005, 10:17 PM   #9
krue
Designated A-hole!
krue's Avatar
Everybody chime in with some good ideas, then we'll copy this over to FAQ.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 08-24-2005, 10:54 PM   #10
TireSmoke420
One of the few GMC'ers
TireSmoke420's Avatar
2x4 bolted to floor under gas pedle works wonders
87' Silverado 4x4
"Young, Dumb And Full Of Cum"
TireSmoke420 is offline   Reply With Quote
Old 08-24-2005, 11:46 PM   #11
walker
walker's Avatar
I would say adding a fuel injection with a computer and all the sensors would do wonders. An overdrive transmission is also high on the list.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 08-25-2005, 12:45 AM   #12
71chevylongbed
Got Horsepower?
im getting 10mpg now. im running a th400 tranny and 3.73 rear gears
Old 08-25-2005, 07:35 AM   #13
Bowtie67
Bowtie67's Avatar
Replacing the turbo 400 with a 700r4 should help considably, especially if your doing a lot of highway driving, I also am assuming the crower cam is 240 advertised duration and not @.050 unless you have serious compression to back it up.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
Old 08-25-2005, 12:53 PM   #14
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
I don't know that the EFI is going to help much. I have the TPI, 700R4 and 3.73 gears. In town I get 10 and 14 on the highway. I'm going to drop down to 19lb/hr injectors though and see if that brings it up any more. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 08-25-2005, 04:38 PM   #15
bejay
you can just look at newer vehicles that are fuel injected with similiar gear ratio and same engine size and see it is not going to help gas mileage by much if any.
you may still have some room to play with the carb jetting even though they set it with a gas analyzer, as it was probably set to run good and not for gas mileage.
700r4 or changing rearend gears or both.
depending on your camshaft your using you may be able to go with a more efficient running camshaft that would be closer to stock lift and duration.
if you can run taller tires it may help lower your rpm a little at cruising speed also.
bejay is offline   Reply With Quote
Old 08-25-2005, 05:26 PM   #16
Jim_PA
Get a cheap beater Honda Accord. Probably costs less than all these MPG saving mods.
Jim_PA is offline   Reply With Quote
Old 08-25-2005, 05:43 PM   #17
see ten
WTB this ad
see ten's Avatar
Maybe so , but how many thumbs up is that going to score while cruisin down the road?
Old 08-25-2005, 11:06 PM   #18
Jim_PA
Agreed, but if you care that much about a thumbs up, suck it up and pay the extra gas money.
Old 08-25-2005, 11:58 PM   #19
86swb
Born a Chevy Man
86swb's Avatar
A cheap beater Honda Accord does not help us get better fuel milage in our trucks. We could get a motor cycle but we are talking about getting more miles out of a gallon of gas for our trucks.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66
*1986 Chevy SWB Silverado
*1984 Chevy Longbed Silverado
New Kia Sportage (Wife's car and she loves it)
CHEVY, American made w/pride!
If you can read this, YOU NEED TO THANK A TEACHER!
If you can read this in ENGLISH, PLEASE THANK A SOLDIER!
GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS
86swb is offline   Reply With Quote
Old 08-26-2005, 12:09 AM   #20
72str8flush
72str8flush's Avatar
Well that defeats the purpose of why I bought this truck... being able to work on SOMETHING WITHOUT all that complicated computer stuff in it. I partially agree that you need to suck it up when choosing to drive these classics or get a beater lil car, but we should try to conserve as much as we can while still having fun in these trucks.
I also have an electric fan on mine and agree that it seems to do wonders. I recently switched to a lower profile air filter element and surprisingly that seems to be lowering my MPG, so I may go back to a taller one. Just my two cents.
72 Chevy Short Bed Fleet: 350/TH350 - Sold - Now trying to sell the parts that I have left over.
_______________________
2006 VW GTI
72str8flush is offline   Reply With Quote
Old 08-26-2005, 12:13 AM   #21
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
I've been driving around like the roads are icy. Easy acceleration saves tons of gas. Keeping the pedal off the floor saves alot too. I've been trying to keep it under half throttle most of the time.
'69 Chevy 3/4 ton, 327cid, Carter AFB, Edelbrock intake, HEI, TH400.
Founding member of the No Money To Spend On My Truck Club.
When your at Home Depot, you WISH you had gotten an 8 foot bed!
Cat Fuzz is offline   Reply With Quote
Old 08-26-2005, 03:35 AM   #22
rwgregory
I put a quart of Slick-50 into a 1-ton Ford Van I used to own and my MPG got better
by 3 miles per gallon immediately. I don't know if that stuff does what they claim, but
it paid for itself within 6 weeks of using it. At today's gas prices, it'll probably pay for
itself after the first fill up.
rwgregory
67 GMC 2500 ,2w/d wide box
305 V-6, 4-speed
rwgregory is offline   Reply With Quote
Old 08-26-2005, 05:46 AM   #23
4x4Poet
Do a mileage check, then change the engine, diff, and manual trans (if so equipped) oil to a quality synthetic (preferably Amsoil, IMO). Repeat mileage check with same driving technique and usage (all highway or all city or daily commute with no differences, etc.). Cheap thing to try for maybe up to one mpg increase. Possibly two.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 08-26-2005, 09:13 AM   #24
wlarue72
see ten
I really like your set up with the electric fan, but flex a lite web site does not recommend for the main cooling source on a 4 core radiator. What do you think about this. I have a big block with air and a 4 core.
David
72 Cheyenne Super 402 daily driver. A lifetime project!
wlarue72 is offline   Reply With Quote
Old 08-26-2005, 10:47 AM   #25
8bolt
Gas up here in Canada is near 5 bucks a gallon I hope this will make your truck seam a little easyer on gas.
8bolt is offline   Reply With Quote
