Old 08-24-2005, 04:17 PM   #1
wink05
Engine ID ????
Previous owner preformed an engine swap in my '67 C10, now trying to identify and determine if it's a desireable block to rebuild, (not into mega HP, more into dependability).
Here's what I have---
Engine Casting: 3970010
Engine Date: J 30 8 (may be a 6, sure looks like an 8)
Casting #: V1104TYZ
Blk Vin: T7F711781
The intake and exhaust manifolds appear to have been switched out, retains the original 2V Rochester.
If it happens to be a 350, is it possible to determine if it's a 2 bolt or 4 bolt without pulling the pan?
Is it worth searching for a 350 block with the "010" and "020" stamped behind the timing chain cover?
Thoughts on going with/rebuilding a 283 ?
Thanks in advance for the help!!!!!!!!!!!!!!!!!
wink05 is offline   Reply With Quote
Old 08-24-2005, 04:22 PM   #2
fade94
fade94's Avatar
www.mortec.com Could be any of the following...
3970010....302.....69....4...Z-28 Camaro
3970010....327.....69....2...Trucks and industrial
3970010....350...69-80...2 or 4
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates)
67 short step project (will get SWB from the 68)
67 Camaro, #'s matching (my wife's)
03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear
fade94 is offline   Reply With Quote
Old 08-24-2005, 04:40 PM   #3
john
member #16
john's Avatar
TYZ= 1975 LS9 350Ci 165 HP 4bb c10-c2500
john is offline   Reply With Quote
Old 08-24-2005, 05:03 PM   #4
CHEVYE
my gas saver
CHEVYE's Avatar
that is a good block to build. there is no way to tell if it is a 2 or 4 bolt until you drop the pan. 2 or 4 doesn't matter much anyway if it's built right.
85' SWB, 4.3/TH350, getting ready for paint
84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black
71`SWB, project
ebay feedback
CHEVYE is offline   Reply With Quote
