Old 08-24-2005, 09:01 PM   #1
Solver
Solver's Avatar
Need carb guru
My quadrajet has a problem.
I can get in and crank and crank and no fire.
if I take alittle bit of gas and dump it down the carb she fires right up and ------stays running!!!!!!! and runs fine after that
butterfly is closed when trying to start it so the choke is working. Filter is new and so is the filter in the line before the carb.
how about some suggestions. Far as I know it is a rebuilt carb.
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 08-24-2005, 09:24 PM   #2
64fleetside
Core plugs on the bottom are leaking fuel, common prob on q-jets. Pull carb, turn over, pull baseplate,epoxy all core plugs, reassemble. Brian
64fleetside is offline   Reply With Quote
Old 08-24-2005, 09:28 PM   #3
JimKshortstep4x4
Talking
Is the accelerator pump shooting a good stream of gas when you pump it?
Jim
Old 08-24-2005, 10:01 PM   #4
acloco
Fuel filter in backwards....you might be surprised.
acloco is offline   Reply With Quote
Old 08-24-2005, 11:49 PM   #5
walker
walker's Avatar
I vote with 64, core plugs. Just pump the accelerator and see if fuel is coming out. No gas outta the squirters is a good indication.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 08-25-2005, 04:48 PM   #6
Solver
Solver's Avatar
Jim K is the winner!!
I pulled the carb and checked the accelerator pump and the rubber was off the bottom end. swapped pump rods and now she starts!!
Thanks for all the suggestions and will have to check to see if the core plugs are leaking in the near future. At least it starts and runs now.
Thanks again
Shannon
