Old 08-24-2005, 10:24 PM   #1
red86chevy
Front 2" drop coil springs
Well I finished installing my 2" drop shackles on the rear the other day, now the front needs to come down a little also. I was thinking of ordering some 2" lowering coil springs from sumitt. If I install these will I need to replace the shocks with some that are made for lowering or will the stock ones be ok? Will any other components be affected?
Thank you,
Jeremy
86 c-10 383 w/ sportsman II heads comp 286h cam Edlbrock RPM Performer intake Holley 750 th350 w/2400 stall 3.73 gears with powertrax No-Slip posi unit. Just broken in good. Will get a 1/4 time this week.
red86chevy is offline   Reply With Quote
Old 08-24-2005, 10:46 PM   #2
iceman7329
iceman7329's Avatar
Shorter shocks will be needed. Thats about it.
iceman7329 is offline   Reply With Quote
Old 08-24-2005, 11:44 PM   #3
hotrodhomi
hotrodhomi's Avatar
use spindles it will ride better.
hotrodhomi is offline   Reply With Quote
Old 08-25-2005, 08:40 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
At least it won't change your ride. If you like your ride now, spindles are the way to go, and they don't "require" you to run a shorter shock.
On the other hand if you would like your truck to handle the corners without leaning so bad then lowering springs and a good shock will make a big difference. If you are looking for better handling, install an anti-sway bar if you don't already have one.....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-25-2005, 08:40 AM   #5
bwright
I went from 3" drop coils to 2" spindles and 1" coils on my old 88 S10....there was no difference in ride quality. The only difference I felt was a lighter wallet.
bwright is offline   Reply With Quote
