Old 08-24-2005, 11:02 PM   #1
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Installed a new air cleaner!
Nothing too special...just wanted to see how many of you guys were bored enough to look.
It is part of the project to clean up the nasty old engine that was in my 71 Cheyenne SWB. I got the truck painted in a hurry and didn't get the engine cleaned up first...that is not the way to do it...what a mess.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 08-24-2005, 11:10 PM   #2
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
...as you can see I powdercoated the intake, pulleys & brackets. Matching valve covers and notice I hooked up the pcv valve (built in breather) and the vent hose from valve cover to air cleaner. I use a 1" aluminum spacer to lift the air cleaner just enough to clear the hei. The stock tin spacer is just too tall and not cool.
Phone: 360-956-7170
Old 08-24-2005, 11:16 PM   #3
matt67350
matt67350's Avatar
Looks good,
Does the breather make any faster?
69 swb stepside, rebuild and upgrade in progress
matt67350 is offline   Reply With Quote
Old 08-24-2005, 11:24 PM   #4
ZOOMY
rocker covers
Frank, Do you sell those rocker covers ? If not, what brand are they ?.....Thanks...........Zoomy
ZOOMY is offline   Reply With Quote
Old 08-25-2005, 12:30 AM   #5
tomatocity
tomatocity's Avatar
Originally Posted by matt67350
Looks good,
No but it makes us breathe better I have done this on all of my cars since...? People used to ask why I did it on my 62 Impala SS. I gave them the same answer. Its available, Looks clean, and Can't hurt.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 08-25-2005, 12:33 AM   #6
tomatocity
tomatocity's Avatar
Looks very nice with a good mix of color, finish, and texture. May I ask what the powdercoating cost and what color the intake manifold is?
Old 08-25-2005, 01:02 AM   #7
Castiron9
72 LONGHORN OWNER
Castiron9's Avatar
Looks Great ..Frank...............................
72-SUPER CHEYENNE/20 LONGHORN
70-C/30 DUALLY
Castiron9 is offline   Reply With Quote
Old 08-25-2005, 02:19 AM   #8
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
I do stock & sell the valve covers & air cleaners and 1" spacers.
The intake is silver metalic. It has a lot of metal flake in it. I can't give you a price as I have a lot of pieces done and get commercial rates. Remember the center ports are probably going to burn off if you have the open intake gaskets for stock choke.
I drill & tap the bottom of the air cleaner and use a heater hose fitting to connect the hose to an elbow in the valve cover. The hose to air cleaner is just a lot cleaner & dryer than breathers on a daily driver. The pvc alone lets the motor build up too much pressure and blows out the gaskets. Don't ask me how I know.
Phone: 360-956-7170
Old 08-25-2005, 02:37 AM   #9
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Frank...your carb is on backwards! It is going to make your engine run backwards. Don't start it...SERIOUSLY!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 08-25-2005, 11:53 AM   #10
724wdcopper
graphic designer
724wdcopper's Avatar
you are kidding, right? definately not backwards...
724wdcopper is offline   Reply With Quote
Old 08-25-2005, 12:10 PM   #11
stllookn
stllookn's Avatar
Old 08-25-2005, 12:52 PM   #12
70GMC_BOB
looks great
1972 chev c20 2wd lwb 350v8/th350. (dad's)1970 gmc longstep (9ft commercial bed), 1 ton, 2wd, 350/th400.
70GMC_BOB is offline   Reply With Quote
Old 08-25-2005, 12:59 PM   #13
Ole Blue 68
Ole Blue 68's Avatar
Hey Frank,
Where did you pick up that PCV valve and vent hose? I need to do the same on my '68.
Thanks,
John
Ole Blue 68 is offline   Reply With Quote
Old 08-25-2005, 11:15 PM   #14
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
pcv/breather
Try Summit or Jegs...The hose is just hose and the air cleaner fitting is a heater hose fitting. I cannot remember where I got that elbow and I need some more.
Phone: 360-956-7170
Old 08-26-2005, 08:09 AM   #15
mcleoud151
NIce lookin' engine man.
'72 C20 fleet, rear leafs, front coil, 350 w/ 350TH (toast now). Dad's got the '71. A Huge work in Progress...
mcleoud151 is offline   Reply With Quote
Old 08-26-2005, 08:23 AM   #16
68C15
blood type; Retumbo
68C15's Avatar
looks REAL nice
I like the fuel line to the carb. clean & neat, not over done
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
