Old 08-25-2005, 10:19 AM   #1
Crush
Active Member
Crush's Avatar
FINALLY...but have a question
Well as of 10:30 last night the "project" has it's SSBC Force 10 front calipers in place. It's been an uphill battle but they are finally on and clearing the wheels.
Here's the question...In order to get them to clear the wheels I had to run a 5/16" spacer....this gives me about 1/4" of clearance between the caliper and the wheel...is that gonna be enough? I was told by SSBC that "As long as they clear when everything is torqued down, it doesn't matter if it's 1/16ths of an inch." I'm just concerned with flexing or something. Am I just being concerned for no reason?
D.M.C -FF-
Crush is offline   Reply With Quote
Old 08-25-2005, 12:00 PM   #2
bigblock73
yeller
bigblock73's Avatar
I think you will be just fine...I personally wouldn't worry about it.
bigblock73 is offline   Reply With Quote
Old 08-25-2005, 12:07 PM   #3
75stepside
*Proud Member*
75stepside's Avatar
been there! i fabbed up 2001 rear discs (12") in the rear of my project... only to take my new 15x10 cragar ss's out of the box and see the disappointing truth.... they didn't fit... i ended up going with a different rear disc setup (from 97 camaro, 11.5" discs) after 3/16 spacers, they fit... i've got probably 1/8" clearance.... and not looking back! :-)
75stepside is offline   Reply With Quote
Old 08-25-2005, 12:56 PM   #4
Crush
Active Member
Crush's Avatar
Thanks guys...What I kinda felt but wanted to know if anyone else had calipers that close.
One good thing though...They look BADASS being that close to the wheel!!
D.M.C -FF-
Old 08-25-2005, 02:28 PM   #5
75stepside
*Proud Member*
75stepside's Avatar
any pics!?
Old 08-25-2005, 02:32 PM   #6
Crush
Active Member
Crush's Avatar
Hopefully this weekend.
D.M.C -FF-
Old 08-27-2005, 02:52 AM   #7
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Good to hear you got your wheel/ brake clearance issues resolved. Out of curiousity, what type of spacer are you running? (Billet AL). I guess the SSBC brakes won't clear the wheel regardless of the BS.
Sounds like you're making some progress.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 08-27-2005, 10:20 AM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
And the pics are where?????
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-29-2005, 10:31 AM   #9
Crush
Active Member
Crush's Avatar
boxrodz -
The SSBC setup has been a journey. When I initially ordered the whole setup I SPECIFICALLY asked if any other modifications would be needed (since I hadn't ordered my wheels yet) and was told that as long as the wheels were 17's or bigger then "no problems". So I got everything in and put everything on and "clink"...wheel "face" hits the caliper... I call SSBC and they tell me that different wheels fit different ways...blahblahblah...and basically I'll either need to order the wheels with thicker hubs to compinsate for the difference or run a spacer... So I call Chris at Boyds and talk to him about re-hooping the front wheels....$250 a wheel plus shipping.... NO THANKS! Sooo I sent the truck on to the paint shop and really just haven't messed with the brakes until last week. I was cleaning up the garage and saw the calipers just sitting up on the shelf. Took them down, mounted them up and took some measurements and figured that a 1/4" spacer wouldn't be quite enough but a 1/2" would probably work. Went up to NAPA and saw they had the 5/16" spacers so I got them and took them home.....taaa-daaa, they worked.
I'm running a simple 5/16" aluminum spacer for now. I am hoping to have a set of billet ones made in the near future, but need to find someone that will do it.
Other than that one issue...the SSBC setup is VERY nice.
N2TRUX - I know I know.....unfortunately the wife "lost" my digital when we were down in the Keys...I'll try to bum one from the neighbor this week. (Plus I kinda need to clean up the wheels and calipers (they USED to be polished ) for the pics).
D.M.C -FF-
