Old 08-25-2005, 11:07 AM   #1
Purs
Got Big Block?
Purs's Avatar
to much rake?
what do you guys think? Do I have to much rake? I think I'd like it more with about an 1" or maybe 2" less. Very slight rake is preferred, Level is OK, but rear lower than the front will not cut it. These springs are supposed to be 4" drop but I'm thinking not. I'm going to try some different springs today.
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 08-25-2005, 11:15 AM   #2
Putter
More Cowbell....
Putter's Avatar
I like it like that.....but maybe 1 more inch wouldn't hurt too much!!!
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 08-25-2005, 11:16 AM   #3
FormerMember
I like it like that as well. My stock one is too much.
Are those new springs? If so, they will probably sag a bit after some usage.
FormerMember is offline   Reply With Quote
Old 08-25-2005, 11:45 AM   #4
mocwon
Keep On Truckin'
mocwon's Avatar
Personnaly, I'd drop it 1-1/2" to 2" more in the rear after driving it a awhile if it doesn't settle out close to level.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 08-25-2005, 11:57 AM   #5
redhead69
fugedaboutit
redhead69's Avatar
I agree that it does not look bad as it sits now.. but 1-2 more down in the back would look just awesome. Nice truck btw.
Currently truckless
redhead69 is offline   Reply With Quote
Old 08-25-2005, 11:59 AM   #6
tomatocity
tomatocity's Avatar
I am agree with you, a little rake is good. What if you are going to haul heavier stuff?
Did you measure the height before installing the rear springs?
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 08-25-2005, 12:01 PM   #7
Frizzle Fry
Frizzle Fry's Avatar
Bring down the house
Frizzle Fry is offline   Reply With Quote
Old 08-25-2005, 12:03 PM   #8
Purs
Got Big Block?
Purs's Avatar
I did measure the stock height but don't know what I did with the numbers.....
Don't plan on doing alot of "heavy" hauling, mostly just hauling @ss....
Old 08-25-2005, 01:58 PM   #9
71RestoRod
71RestoRod's Avatar
Nice truck. IMO, too much rake for the drop front. Get the gap between the tire and wheelwell the same front and back and you will have a perfect 1 1/2" - 2" rake.
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod
71RestoRod is offline   Reply With Quote
Old 08-25-2005, 02:02 PM   #10
HeavyD
HeavyD's Avatar
I think too much rake as well.
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 08-25-2005, 03:04 PM   #11
70short/step
70short/step's Avatar
Put some bags of cement or something else heavy and then look at it. I think it looks good the way it is, but still think it would look better a lil lower in the rear.
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
Old 08-25-2005, 03:11 PM   #12
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Looks Great To Me!
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 08-25-2005, 04:03 PM   #13
mplex2000
mplex2000's Avatar
Looks like your back tires are fatter than the fronts....maybe that's pushing it over the edge. Most people I've talked to that have the 2.5/4 inch drop said their rear is higher than they like.
mplex2000 is offline   Reply With Quote
Old 08-25-2005, 04:04 PM   #14
mplex2000
mplex2000's Avatar
BTW - I think 2.5/6 gets you level if your front and back tires are the same.
Old 08-25-2005, 04:11 PM   #15
Purs
Got Big Block?
Purs's Avatar
255/60/17's on 17x8's in the front and 285/60/17's on 17x9.5's in the back (ala Copperhead). I think the fronts are around 29" tall and the back's are almost 31" tall.... maybe this is why... thanks mplex2000.
Old 08-25-2005, 04:34 PM   #16
Primered_69
Primered_69's Avatar
Also, is the bed wood installed? That could count for the higher higth in back.
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline   Reply With Quote
Old 08-25-2005, 04:57 PM   #17
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I was going to mention the tire size. Also, the first pic exadurates the height in back. The sunlite coming in through the floorless bed makes the gap obviouse, while it is almost impsible to see what the gap is in front.
IMO, it look sbad ass like that...but I think rake is needed. I think cars and trucks look funny perfectly level...onless it is some plush girly land yaght like the town car I been reluctantly driving for a year now.
Old 08-25-2005, 06:41 PM   #18
Dual quad
Smell that burnin' rubber
Dual quad's Avatar
I think it looks decent, but a bit more drop in the rear would level it out.
Let us know what the wheel back space F & R is that you used, and also who the tire manufacturer is (Nitto?). I just did an ECE 4/6 drop and am probably going with the same wheel and similar tire combo as you (except 275/60/17 rear). The 285/60 tire is extra tall and adds to the rake issue.
Very nice ride!
Dual quad is offline   Reply With Quote
Old 08-25-2005, 07:41 PM   #19
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Nice truck! Keep some rake, but maybe an inch or so less than what's on there now imo...
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 08-25-2005, 07:43 PM   #20
69 longhorn
I like a little "nose down" attitude on the trucks, & say she looks good as is. I agree with all the guys, & will say again.....if you dont have the box floor in, i would do that 1st, & also let the springs "settle" a bit. other than that, I wouldnt drop that more that 1 extra inch on the rear. Im still workin on 1 more inch on the nose of my 69.....sweet truck, 69L
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 08-25-2005, 08:03 PM   #21
Purs
Got Big Block?
Purs's Avatar
thanks for all the input guys. Well I just finished putting the "cargo" chevelle springs on and it actually raised the truck up several inches....
As far as the floor goes, it's steel. The only part that isn't there are the wheel tubs. I'm in the process of a mini-tub. So the weight won't be much different once I put them back in. Also, the springs were used when I got them so the "settle" factor may not make that much difference either. It's close to being just like I like it with the other springs. I guess I'll start looking for some 1" or maybe 2" lowering blocks. Anybody got some?
Old 08-25-2005, 11:17 PM   #22
lamar
lamar's Avatar
Hey what size tires and wheels? 17-9.5 rear 17-8..5 frt 285 rear tire/ Looks like a touch lower would be dead on level. Looks good, Lamar.
72 C-10
lamar is offline   Reply With Quote
Old 08-25-2005, 11:45 PM   #23
N2TRUX
Happy to be here
N2TRUX's Avatar
Too much rake and too tall of a rear tire. Drop em both a couple of inches....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-26-2005, 12:33 AM   #24
AesC10s
Chevy truck addict
AesC10s's Avatar
i like the way it sits.
AesC10s is offline   Reply With Quote
Old 08-26-2005, 04:19 AM   #25
69 Short Fleet
Is your swaybar already installed? Mine raised my front end @ 3/4"-1". Just a thought. Your rake tooks great to me, very nice truck by the way. Doug
69 Short Fleet is offline   Reply With Quote
