steering box adjustment
Does anyone know the proper steps on how to adjust my steering box in a 72shortbed K10?
Thanks for any help.
--------- 72 SWB K10 San Diego CA |
I wanna know
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
20' Daredevil (Ret)
![]() Join Date: May 2003
It's generally not recommended - most guys will say if it needs adjusting, it needs replacing. However, I can tell you what I have done (successfully) but you do it at your own risk! I am not advising you to do this!
On top of the box is a large slotted adjuster head held in place by a jamnut. Use a large screwdriver to hold it firmly in position while you loosen the nut. Turn the adjuster clockwise just a small amount, then tighten the jamnut and try it. If you overtighten the adjuster, the steering will drag, and will not return to center freely on its own. If still too loose, you wil still have excessive play. Experiment until you get it right. It's a simple procedure but you must be aware that the steering may become difficult, and be prepared for it. This will likely just buy you some time until you will need to replace the steering box.
![]() Join Date: Jul 2004
Use right hand to rock the rag joint back and forth slightly while slowly turning the adjuster screw, you can feel when most slop is gone, the screw turns easy, just don't tighten to far. This has worked on every power setup I've had, most manual setups I have tried just keep getting looser over time, but helps them for a while.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
Worked just fine for me. Thank you very much. I turned it about 3/4 of a turn and its tight enough for me.
