Old 08-25-2005, 09:09 PM   #1
ScottH
ScottH's Avatar
Can someone tell what this does?
The part in question is the piece that is mounted on top of the thermostat housing. Two vacume lines hook to it. The one on my 76 454 is broken and I'd like to know if I can eliminate it or if it should be replaced. BTW the air pump on mine has been removed, not sure if it is related but thought I would mention it.
Thanks for any info.
ScottH is offline   Reply With Quote
Old 08-25-2005, 09:35 PM   #2
iceman7329
iceman7329's Avatar
Never seen one of those. Kinda strange.
iceman7329 is offline   Reply With Quote
Old 08-25-2005, 09:41 PM   #3
ureckme
ureckmefixit2@cox.net
Its a themostat housing w/ a thermo vacume switch. It might go to your EGR? not enough info. Matt
That's U RECK ME FIX it 2
74 Chevy Short Bed
355ci Sportsman II 64cc Angle Plug
Crower Custom Grind .462in .486ex
Dyno Test 422hp @ 5600
And it's got a Holley
3.73 Gears
12 Bolt 3.73 w/Posi
700R4 Going In
I'm a Body Man So There!
That's why it's not painted
ureckme is offline   Reply With Quote
Old 08-25-2005, 10:52 PM   #4
bodydropped
not sure but my 78 doesnt have it or it did and broke off but i dont think u need it
bodydropped is offline   Reply With Quote
Old 08-25-2005, 11:04 PM   #5
82c10
needin' money
eliminate it
SWB Stands for Short Wide Bed
82c10 is offline   Reply With Quote
Old 08-25-2005, 11:37 PM   #6
bagged74
its just $$$$$
bagged74's Avatar
EGR parts, just scrap it.
bagged74 is offline   Reply With Quote
Old 08-26-2005, 12:13 AM   #7
jermasaurus
jermasaurus's Avatar
Does it go to the thermostatic air cleaner or heat riser? I think it might.
-Jeremy
jermasaurus is offline   Reply With Quote
Old 08-26-2005, 12:21 AM   #8
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
my 79 has one like that just has more ports. if you scrap it how do you re-rout the vacume likes? I actualy have two ports like that. the other is on the manafold and is kinda purple.
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 08-26-2005, 02:29 AM   #9
hotrodhomi
hotrodhomi's Avatar
mine has 4 ports on my '81.
hotrodhomi is offline   Reply With Quote
Old 08-26-2005, 09:35 AM   #10
86 GMG
i believe it is in relationship with the ???/heatriser???? something or nother to work a smog control unit of some sort basically scrap it and plug the lines that connect to it as well these truck had a lot of vacuum lines originally and they run like crap with them all there imo.
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
Old 08-26-2005, 10:31 AM   #11
60-66 Nut
Professional Beer Tester
On the 454's that we used to have in our fleet(about 60 at one time) that switch was used to regulate the distributor vacuum advance. As I recall, it would switch the advance from ported vacuum to manifold vacuum or vise versa when the engine warmed up. Like everyone else said, it's not necessary. Just make sure the vacuum advance is hooked up.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 08-26-2005, 11:25 AM   #12
PHOENIX
Thermal vacuum switch.
It regulates vacuum to components based on coolant temperature (engine warm up).
It could be used for a few things.
If the vacuum lines are all hooked up and everything is working fine I wouldn't remove it.
If you do have to keep your EGR you need to keep atleast one of the TVS's with two ports, one in, one out.
My a.i.r. pump vacuum line was not (and is not) routed through a TVS.
My TVS is only used for the egr (i believe there is a line to the canister also).
I used to have a TVS with more ports. One went to the heat riser.
The heat riser is located on the bottom of passenger side exhuast manifold.
It help the engine to warm up faster.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
