Old 08-25-2005, 10:47 PM   #1
Fatback
Fatback's Avatar
heater hose question
Does it make any difference where the hoses go from intake/water pump to heater core?? Thanks
70 C/10 LWB
69 Cougar
68 Mustang
68 GMC 4X4 SWB
Fatback is offline   Reply With Quote
Old 08-25-2005, 10:55 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
not really. Hot water in....cool water out.
Old 08-25-2005, 11:08 PM   #3
Fatback
Fatback's Avatar
Thanks...just wanted to be sure.
70 C/10 LWB
69 Cougar
68 Mustang
68 GMC 4X4 SWB
Old 08-27-2005, 10:51 PM   #4
da-burb
"Ochre Ogre"
da-burb's Avatar
Huh? There is a right way to do them. 5/8" hose from the intake manifold to the bottom of the heater core. 3/4" hose from the top fitting to either the radiator or the water pump depending on what you have.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 08-28-2005, 07:36 AM   #5
70GMCer
70GMCer's Avatar
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 08-28-2005, 08:45 AM   #6
Fatback
Fatback's Avatar
I know its a dumb question....But the reason I asked was, I hooked everything up as follows:
Top core 3/4 to the intake....Bottom 5/8 to the nipple on the water pump.
I did it thinking that was the way it went. I started looking at pictures on here and see they are the way you describe. I'll have to go buy more 3/4 heater hose to change it. Thanks!
70 C/10 LWB
69 Cougar
68 Mustang
68 GMC 4X4 SWB
Old 08-28-2005, 11:32 AM   #7
Longhorn Man
That will work perfectly fine. It makes no differance which is on top, nor what size hose you use, as long as you have hot water flowing in, and not as hot water flowing out.
Old 08-28-2005, 05:23 PM   #8
chipflyer
chipflyer's Avatar
Hey Fastback,
To be correct it needs to be the way da-burb posted. While it will work hooked up backwards, its not the way GM intended it to be setup. The hotest water in the engine goes out the 5/8 hose on the intake and goes into the lower nipple on the heater core also 5/8. Cooler water returns from the top 3/4 inch nipple to either the radiator or waterpump which will also be 3/4. When dealing with hyrdaulics or any kind of fluid pressure system, the return line will always be the larger line. Thats why one nipple is 5/8 and the other is 3/4, they didn't accidently do that!
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 08-28-2005, 08:18 PM   #9
hilljob26
hilljob26's Avatar
will it hurt it if it is backwards,is there something that can happen,or will the heater just not be as hot,just curious
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 08-28-2005, 10:44 PM   #10
Longhorn Man
not as hot? Nothing you'll ever be able to feel...no damage either.
Old 08-28-2005, 11:12 PM   #11
Fatback
Fatback's Avatar
It's correct now. Thanks for the info!!
70 C/10 LWB
69 Cougar
68 Mustang
68 GMC 4X4 SWB
