Old 08-26-2005, 12:14 PM   #1
68cajun
68 C/10
68cajun's Avatar
Cutting front springs?
How much would i have to cut off the spring to lower it 1 1/2" on the front.I have 2 1/2" drop spindles and would like 4" total on the front. Anyone done this?
(2009) GMC Sierra Denali 6.2 AWD
(67 C/10 fleetside SWB)
(2018GMC Yukon Denali) Wifes Car
68cajun is offline   Reply With Quote
Old 08-26-2005, 12:56 PM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
springs
I cut one ring out of my springs years ago and it dropped the front end about 2-3 in.
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 08-26-2005, 01:06 PM   #3
72BLAZERDUDE
72BLAZERDUDE's Avatar
Your kinda stuck because if you are going to cut them it should be 1 full coil only from the bottom Otherwise the spring doesn't sit in the a-arms correctly.The ends of the springs have to be the same in relationship to each other as the stock ones are. With 1 full coil you get about 2 - 2 1/2 inch drop. Here is a picture of my sons truck with 1 coil cut and 2 1/2 drop spindles. Also has 6 inch rear drop coils and 2 inch drop blocks.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 08-26-2005, 02:29 PM   #4
68cajun
68 C/10
68cajun's Avatar
looks like i'm ordering some new springs.
Old 08-26-2005, 06:30 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Why can't you cut half a coil? The springs aren't pig tailed are they?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-26-2005, 06:36 PM   #6
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
Just Try It !!! You Might Like It !!!
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 08-26-2005, 11:33 PM   #7
67sss
67sss's Avatar
cut my front ones 1/2 coil and yes they do "klunk" every once in a while, did this probably 10 years ago.
67sss is offline   Reply With Quote
Old 08-27-2005, 12:00 AM   #8
pissonNOS
senior member
pissonNOS's Avatar
i cut a coil and a half but i used 3/4 ton springs and it lowered me 3 inches and i cant really complain about the ride quality either
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 08-28-2005, 10:07 AM   #9
modifiedGMC
I cut 1 and 1/4 coil from the bottom of the front on mine but I rotated the coil so the end would rest back in the dipped out area of the a-frame where it started. I done this with the truck jacked up so the spring wouldn't be compressed. It did affect my caster and camber adjustments some but here is what it looks like. No drop spindles just cut coils. I running 235 70R15 tires all way around.
If it don't fit, force it,...If it still don't fit , modify it 'till it does fit !!!
modifiedGMC is offline   Reply With Quote
