Old 06-30-2002, 01:03 AM   #1
CHUCKER
lost truck keys
I need to move my truck but I can't find my keys. is there any way to start these trucks with out putting in new ignition or is it easy to put new ignition in? thanks for your help
1972 K/20,4X4,454, dark olive
1937 General motors truck (big project)
2005 gmc envoy (wife's)
2003 2500hd ls, crewcab, 4x4, 360, hd 4spd automatic trans.,
Lee's summit, MO. S.E. of Kansas City,MO
CHUCKER is offline   Reply With Quote
Old 06-30-2002, 01:10 AM   #2
CE20934
CE20934's Avatar
Location: Help! I'm in an office park with its own network of freeways!
Batt power to coil (yellow on my truck), momentary power to starter (purple) solenoid.
That's with points. I believe HEI can be hot-wired in a similar fashion.
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man)
'95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis)
'07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed*
CE20934 is offline   Reply With Quote
Old 06-30-2002, 01:13 AM   #3
CHUCKER
it is HEI
Old 06-30-2002, 01:20 AM   #4
CE20934
CE20934's Avatar
I'm pretty sure it'd work. HEI gets constant 12V to the coil anytime the key is on, so you're not going to blow up the coil doing this.
I don't have a running HEI-equipped vehicle handy, so I can't test my theory.
Old 06-30-2002, 01:54 AM   #5
WORNBRAKES
That is why I like that my keys fall out of the ignition with it running. A screwdriver would start my truck if I was to misplace the keys. I have another ignition sitting in the garage. Maby I should change them out some day.
P.S. Don't tell anybody. LOL
Mario and Mandy
Hughesville, MD 20637
69 C10 305/350
71 K5 Basket case
75 K10 Rescue **Parting out**
77 MG Midget **Parting out**
15 6.7L Cummins
WORNBRAKES is offline   Reply With Quote
Old 06-30-2002, 01:56 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Yup...it'll work too.
Run a wire to your HEI where you plugged it in (batt terminal) and run a wire to the s sterminal on your starter. I would leave these two connected for now, then clamp the coil wire onto your pos on the battery, and touch the one from your starter to your pos terminal till it starts. You'll need to disconnect the coil power to kill the engine.
Notice, that your battery will not charge like this, so don't try driving it to the store or anything...
I'm going to have to do this to the Longhorn since I ripped out the whole under hood harness and was reminded AFTER the fact that we are repaving the drive way next week or so.
Old 06-30-2002, 03:41 PM   #7
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
Having started a lot of cars in the past, it is easiest to open up the harness just as it comes out of the firewall connector, there you have your porple (starter) and pink (ignition), and 12v (red) wires. bare a spot on them so they cannot touch, use your always reuired alligator clipped jumpers from red to pink and touch purple to start. You can Also carry an ignition switch and simply unplug the plug from the old lock and plug it into your switch. That will not light up the gen and brake warning lights unless you ground the swiitch.
Nevada City, CA
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
Old 06-30-2002, 04:56 PM   #8
CHUCKER
thanks for your help. i'm going to try moving it tommorow. hopefully i'll find my keys by then, but with the house mostly packed up already its hard to say where they might be.
Old 06-30-2002, 09:22 PM   #9
fluffytx1
fluffytx1's Avatar
I agree
I did the fire wall application with the purple and pink wire and it worked
1968 GMC CST long wide box
http://groups.yahoo.com/group/67-72-collectors/
fluffytx1 is offline   Reply With Quote
