Removing ignition cylinder - a little help needed
Need to remove & replace the ignition lock cylinder on the 67 - two reasons...I am getting ready to paint the dash and the new lock cylinder matches the doors now.
But......after turning the key to ACC, pressing the release through the small hole, I cannot get the little bugger to budge. Any thoughts? THANKS in advance!!! |
try pushing the button before you turn the key. so with the key in the off position put you paperclip or whatever ur using in the hole and push then turn the key to acc and it should come right out
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
![]() ![]() Join Date: Jan 2005
Once you push the paperclip in, I believe you have to turn the key a bit past ACC before it will come out.
Yes, you do have to turn it a little past the ACC position. I had a heck of a time removing one a couple weeks ago but persistance payed off.
its all about the +6 inches
sometimes you have to yell bad words at it and threaten to kick it's grill in.
Thanks...had a list of items that I wanted completed today....because I wanted to paint the dash and have it ready for assembly tomorrow...late in the afternoon...
Hmmmm...patience....and words.......I will keep you posted. |
I tried off and on for three weeks. Finally I put the key off,inserted the clip, and here is the key for me, I moved the key around alittle until I actually felt the little pin move and felt the spring pressure push the clip back out. When I knew I was on the pin I rotated too and then a little past acc. and bigger then duky the darn thing came out. I have a Cadillac stearing column with the key located in it, so I removed the dash key trim and installed a vacuum guage there.
1969 C10 Long Step,355,700r4w/lockup, HEI,Weiand,750 Performer,1.6 rockers,Camel Humps,Comp 262Extreme,Hedman,2 1/2"pipes, tele/tilt,SunRoof,ps,Disc pb,ac,Cragar,eaton,Corvette style roll pan, Bowtie louvered tail gate,lowered 2/2. |
I thought a 67 ignition switch didn't have an acc position.
72 Cheyenne SWB Fleet/original 402, TH400, buckets & console 65 C10, 350TBI, 700R4 (work in progress) |
~Rest In Peace~
when putting in the new one use some graphite on it
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
72402...I always thought the same myself... but if he says he has it....
woodman13
![]() Join Date: Jul 2004
I used a big screw driver to pop the front off....then cut the keylock off with the chop saw. now it starts with a screw driver...oh you wanted to keep the lock set you have.....Opps sorry I can't help
Woodman13 2007 Dodge Ram 3500 5.9 rolling coal! 1994 Caprice 9C1 88K miles, LT-1, dropped/shaved 1967 C-30 350 4 sp dually 1971 C10 SWB BBC, auto; good driver |
Thanks for pointing out the ACC item....I could not remember either...but this one definitely has ACC.
I will try again later tonight. Thanks for the help....and the screwdriver! |
#13 |
1969 Custom 30 wrecker
Don't use a paper clip, instead, use a small allen wrench. (I learned that here) I had no luck with a paper clip as it kept bending but the allen wrench is rigid and you can press in hard.
I think a little WD 40 might help too.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
#14 | |
Having issues
Quando Omni Flunkus Moritati. The Man's Prayer: "I'm a man, but I can change, if I have to, I guess." |
#15 |
![]() Join Date: Dec 2000
How do you remove without key?
69 C10 ![]() 65 Chevy II |
#16 |
That would be with the assistance of a drill.....
#17 |
No drill needed... http://67-72chevytrucks.com/vboard/s....php3?t=123712
#18 |
...but you still have to get the old one out.....hmmmm....7/16" drill bit should work just fine!
