08-26-2005, 07:01 PM | #1 |
Control Arm Bushing Removal
Just thought I would post this, it's a really easy way to remove the control arm bushings. I found that the ball joing press was easier than using a full size press. I did my lower control arms the same way. My control arms are sandblasted in the pictures.
08-26-2005, 07:08 PM | #2 |
Wish my conrol arms were that clean... and had new bushings.
08-26-2005, 07:56 PM | #3 |
Happy to be here
That sure beats using a torch and a BFH. Those control arms look nice....
08-26-2005, 10:52 PM | #4 | |
its just $$$$$
08-26-2005, 11:18 PM | #5 | |
Workaholic
08-26-2005, 11:36 PM | #6 |
Insert Witty Text Here
I have that same press, and I was going to try using it. Then my neighbor, who used to own a front end shop, offered to do it for me at his old shop. I gave them to him, and he gave them back to me finished. That was even easier!
They look great, BTW. I wish I had cleaned mine up better. Slonaker |
08-26-2005, 11:54 PM | #7 |
No No
I used the air hammer for removal and the ball joint tool for install. I think if I were to have even attempted to use the press to remove the old bushings it would have taken all day to get the 400K miles of rust and grime to budge.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
08-27-2005, 02:39 AM | #8 |
Until Seventy Times Seven
I used the same tool (rental) to remove my outer metal sleeves. But, I first had to drill out the rubber bushings to remove the inner sleeves so that the shafts could be remove. The challenge is installing the second bushing once the first bushing and the shaft in installed. I rigged up a press to do the job.
Nice job on the control arms.
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
08-27-2005, 09:16 AM | #9 | |
- Greg |
08-27-2005, 09:39 AM | #10 |
For my '63 Corvette I used the air hammer with chisel bit to walk the bushings out. I took 1-2 minutes per bushing.
To install the bushings, I used bearing grease to lube the bushing and, using the bar (whatever you call the thing the bushing pivots on) as a guide, I then drove the bushing on to the A Arm using a large socket, tapping each end alternatively. The socket needs to be large enough to go around the metal flange portion of the bushing only. I cannot find it right now, but it was much bigger than what I will ever use for anything else, but only cost $5 at Advance. It probably took about 5-6 minutes to install per pair. |
08-27-2005, 10:07 AM | #11 | |
Happy to be here
08-27-2005, 12:29 PM | #12 |
When removing the rubber out of the old bushing I used a drill and a torch. I used an old drill bit and heated the tip red hot. Then drilled the rubber, when the tip of the drill is red hot it removes the rubber nice and clean. I drilled in about 8 spots evenly spaced around the bushing and then what's left will pry out fairly easily. The drill method is still a little stinky but no where near burning the rubber out.
I'm installing urethane bushings so I will be able to use the press to install the new shells because they come apart and the shafts will slide through the shell. I'll post some pics when I install them. I'm putting in Energy Suspension Polygraphite Bushings, has anyone had trouble with these squeaking? I'm considering drilling them and installing grease zerks. Last edited by Kopper; 08-27-2005 at 09:01 PM. |
08-27-2005, 11:50 PM | #13 |
i recently changed all the front bushings and ball joints on my '80. i figure the ball joints were original since they still had rivets and not bolts so i could imagine so were the bushings, huh?? anyways, i thought the torch and the BFH was the fun part of the job, even got my boy away from the tv if it meant he could play with torch. (supervised of course)
08-28-2005, 12:49 AM | #14 | |
A couple of things, make sure the C-clamps are securely aligned in place. When pressing in the bushing, alternate tightening the clamps a little at a time to maintain that the bushing is pressed in correctly during the process. Be careful. Next time, I'll make arrangements to have a shop press them in. Good luck.
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... Last edited by boxrodz; 08-28-2005 at 12:50 AM. |
08-29-2005, 09:12 AM | #15 |
Thanks for the pic. I got the upper arms done pretty easily. I put the bushings in the freezer for about an hour to shrink them a bit. Then I used 80 grit sandpaper to clean up the bores on the control arms so I had shiney metal all the way around. Also lubed them up with some motor oil. Took a bushing from the freezer and dropped it in then smacked it with a 2lbs hammer. I had a large 3/4" drive socket over the bushing so I didn't hit it directly. It only took a few hits to drive it in.
Will try the same technique on the lower arms as soon as I can get some new shafts. I buggar'd up the threads on the originals trying to remove the inner sleeves that were rusted solid to them.
- Greg |
08-29-2005, 11:33 AM | #16 | |
Magnificent bastard
1977 Big Block Burb |
