08-27-2005, 01:42 AM | #1 |
Professional Grade
Why does my Alt hum?
Hey all!
I've got a newer style alternator in my truck, as it has serpentine now. I have it hooked up as follows: Thick wire is hooked up to the big post, which goes straight down to the battery, thin voltage sensing wire is hooked up to the old red wire, and the brown idiot light wire is hooked up to the old brown wire through a 75 ohm resistor as I was told to do. The alternator charges like it should when the engine runs (14.9 volts on the nose) but when it is just sitting there, the alternator makes a noticeably loud humming noise. Anyone have any ideas what it could be?
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
08-27-2005, 05:19 AM | #2 |
'87 V20 4x4
is the belt too tight? sometimes it puts torque on the shaft and bearings causing a hum... other than that not sure
Doc
'86 K5 Blazer 4x4 FOR SALE '87 v20 4X4 '99 S10 Blazer 4X4 |
08-27-2005, 10:09 AM | #3 | |
Happy to be here
What do you when it's just sitting there. Are you saying it does this when the truck is not running?
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 08-27-2005 at 10:10 AM. |
08-27-2005, 12:17 PM | #4 |
Is it the alternator making the noise or are you getting feedback through the stereo?
08-27-2005, 01:45 PM | #5 |
Street Rod Restoration
Maybe it dosen't know the words... good luck though seriously.
Follow me on Instagram @ hot_rod_shop |
08-27-2005, 05:19 PM | #6 |
my moms burb does that it comes and goes but its been like this for years it sounds funny thou
http://img.photobucket.com/albums/v5...ropped/sig.jpg |
08-27-2005, 05:52 PM | #7 |
Professional Grade
It hums when the truck is sitting, not running :P
If I unplug the brown wire, and voltage sensing wire, the humming immediately dissapears. Its an electrical hum, and is too quiet to be heard when the engine is attempting to run (TPI needs a bit of work, lol)
08-28-2005, 03:46 AM | #8 |
OutOfMyMind & I'llNeverKnowWhy
I usually get a high pitched humm when there is a large load on the alt, like right after starting when its trying to recharge the batt after sitting for awhile.
-Justin-Out of my mind and I'll never know why 1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed 1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6 1992 Pontiac Firebird T-Top 5.0L TBI 700R4 My cardomain page I don't like to save, it's more fun to spend!! Last edited by Justins76; 08-28-2005 at 03:47 AM. |
08-28-2005, 11:50 AM | #9 |
Professional Grade
yeah, I could understand that, but this is while the truck is not running, and just sitting in the shop. Ignition off, nothing on at all.
08-28-2005, 04:56 PM | #10 |
Born a Chevy Man
[QUOTE=N2TRUX]Maybe it's happier when it hums? Maybe your truck wants to be a Hummer? Maybe it wants a Hummer
QUOTE] Or maby he needs to leave his radio off. No music- maby the humming will stop. I'm sorry, I know, we are bad. But really, do not know why it likes to hum. Never had that happen.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66 *1986 Chevy SWB Silverado *1984 Chevy Longbed Silverado New Kia Sportage (Wife's car and she loves it) CHEVY, American made w/pride! If you can read this, YOU NEED TO THANK A TEACHER! If you can read this in ENGLISH, PLEASE THANK A SOLDIER! GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS Last edited by 86swb; 08-28-2005 at 04:57 PM. |
08-28-2005, 06:01 PM | #11 |
Professional Grade
lol, if only my truck actually had a radio...
08-28-2005, 10:12 PM | #12 |
my dad said ur diodes in the alt are back feedin and thats not a good sign
08-29-2005, 12:13 AM | #13 |
Professional Grade
Whats the best way to stop the feedback? As I mentioned earlier, the alternator works perfectly when the truck is actually running.
If its bad diodes, I've got a very similar alternator that has a bad set of bearings on it that I can replace them with.
08-29-2005, 11:50 AM | #14 |
u can get someone to take the 2 and build u one
08-29-2005, 08:54 PM | #15 |
Shadetree Mechanic
Bad Diodes
I just had an alternator tested and it had a bad diode, it didn't hum though and it was putting out about 15 volts.
14.9 Volts is really too high, it should be around 13.8.
Dave M. (Hacksaw) 86 C10 Scottsdale LWB, 4.3L, Edelbrock 1904, K&N, 700R4, 3.08 Auburn Performance 89 GMC S-15 Extended Cab 4x4, 4.3L, FI 98 K1500 Xcab, 5.7L, 3.43 Gov-Lok |
08-29-2005, 10:31 PM | #16 |
Its probably a bad diode. You don't see it happen very often but i have had it happen to me once before.
DW
Doug Wright aka K5NUTT over @coloradok5.com Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets Certified K5 Nut |
