Old 08-27-2005, 01:39 PM   #1
AspecialZ
Street Rod Restoration
AspecialZ's Avatar
front wheel question...???
will an 18 X 9 with 5.75 BS fit in the front with a 4-6 drop comfortably? anyopne know?
Follow me on Instagram @ hot_rod_shop
AspecialZ is offline   Reply With Quote
Old 08-28-2005, 12:59 AM   #2
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
I don't know for sure, but I think it may work depending on the size of the tire you plan on using. For 8" wide wheels, folks use around a 5" BS on the front. So, a 5 3/4" BS on a 9" wheel may work. Maybe, someone who has done this will chime in.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 08-28-2005, 04:00 PM   #3
truckinbean
What size tire would you be running?
I've run a 17x8 rim with 4.5" bs and a 17x9.5 with 5" bs with no problems on my 77 blazer with a 5" drop in the front. Tire size on both was 245/45zr17, or about 25.7" tall.
A taller tire would probably hit the fender lip and more backspacing might rub the lower control arms at full lock, or possibly the tie rod ends. The best thing to do would be to go to a tire shop that has a rim the size you want and bolt it on to check for clearance issues.
Ben
'77 Blazer 2wd lowered 5/6
Goodwrench 350/700r4/3.73
Performer intake
Performer 1400 carb
Sanderson Headers/Dual 2 1/2" Flowmasters
truckinbean is offline   Reply With Quote
