Old 06-30-2002, 10:07 AM   #1
bigcarguy
Finally a Bulldawg
bigcarguy's Avatar
Leveling out my truck
I have a 72 C10 1/2 ton that sits haunched at the front (the bed sits higher than the front). Anyways, I wanted to level it out so the bed and the front are the same height. I want to lift it so this isn't a lowering question. Would springs from a 3/4ton level it out or is there more that needs to be done? Also, I know this question is probably asked all the time, but what is the widest rim I can put on it with no mods? Thanks for the input.
bigcarguy is offline   Reply With Quote
Old 07-01-2002, 08:28 PM   #2
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Is it a leaf spring truck? If it is just start adding leafs until you get it level. I dropped mine too far, so I started pulling and adding leafs until i got it level. If you want to see what 3/4 ton springs would do, just look and measure one.
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
Old 07-01-2002, 11:08 PM   #3
bigcarguy
Finally a Bulldawg
bigcarguy's Avatar
nope, coil springs
Old 07-02-2002, 04:45 AM   #4
bigvinnie
bigvinnie's Avatar
I guess I'd go for new front coils if yours are old and see how much height I picked up..... how much height difference are we talking about here...???
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 07-02-2002, 09:47 AM   #5
bigcarguy
Finally a Bulldawg
bigcarguy's Avatar
There's not a huge difference, but the bed is noticably higher than the front. I know alot of trucks look like that anyway, but I personally prefer the level look.
Old 07-03-2002, 07:22 AM   #6
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
My truck did the same thing when I first got mine. Easy fix. Get some new coils for the front. If your truck came originally with a 6 cylinder and then was replaced with a v-8 then most likely you have 6 cylinder springs. That was the situation with mine.
Ben
67Fleetsidedream is offline   Reply With Quote
Old 07-05-2002, 04:57 PM   #7
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Most of the trucks come stock about 1-2 inches higher in the rear because the springs are stiffer and when loaded they will drop some. When they are loaded to capacity they are lower in the rear. If you want it to ride level in the unloaded condition then you need to raise the front with stiffer springs (3/4 ton) or put softer springs in the rear. I would go for the softer springs in the rear or just load some sand bags in the back...cheapest way to go. Drive if like that for a few months and see what you think.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
