Old 08-27-2005, 08:53 PM   #1
pritch
pritch's Avatar
My bell crank broke.
30 miles from home, but just pulling away from the last stoplight I would have to stop for before home. I pushed in the clutch for third gear and something snapped and the clutch pedal went to the floor and I just kept on going. Someone pulled out in front of me and I had to downshift into 2nd with no clutch and then back into 3rd, but I never had to stop all the way home.
So now I need a new bellcrank. Is there any difference in them between the I6 and the SBC? I think I have one around here somewhere, but it came out of a V8 truck.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 08-27-2005, 09:12 PM   #2
Randy70C-10
Randy70C-10's Avatar
Nope, no difference
Randy70C-10 is offline   Reply With Quote
Old 08-27-2005, 09:39 PM   #3
69 longhorn
Yes they are different (I6 or v8). you need the 6 pc, or if you have all the pcs,you can Have a local welder "fix" the problem. crazyL
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 08-27-2005, 10:40 PM   #4
pritch
pritch's Avatar
Looks like differing opinions I didn't know what broke when it broke, I didn't think it was a good idea at the time to stop and see, so no, I don't have the piece that broke off I may just have to plan a trip to the junk yard to find one off a 6. No big deal, I just can't do it tomorrow.
'68 Panel
'68 C-10
Ol' Green
Old 08-27-2005, 10:44 PM   #5
hotrodmtodd
'Burban Legend
hotrodmtodd's Avatar
They ARE Different
I will swap you one for a 6 for that V-8 one if you want. OR I can just send you out one on MON if you need it BAD. Let me know with a PM if you need it. Good luck, Mike
'67 Chevy Iron City Beer Truck (9ft step)
'67 Chevy Panel Truck 467
'68 Short Fleet 305v6
'68 McLaren Ramp Truck
'68/'68/'70/'71 Burbs 292/366/402/454
'69 C-30 dump
'71 C-50 dump and church bus
'71 4x4 454
'72 Blazer (w/pop-up camper) $15 x-hooks
'66 Chevy II 194/Weber
'68 El Camino" 305v6
'69 Skylark 455 Buick
'70 Chevelle 427
'71 Cutlass W-31
'71 GTO 400 2x2
"The 51" Chopped '51 Chevy (409) my first car
OK Toad, we'll take 'em all... John Milner
hotrodmtodd is offline   Reply With Quote
Old 08-27-2005, 10:57 PM   #6
69 longhorn
it looks like you may need the bottom rod , from the bellcrank to the throw out fork also. best of luck,crazyL
Old 08-28-2005, 06:02 AM   #7
'68OrangeSunshine
'68OrangeSunshine's Avatar
The V8 Z-bar is 7" across and the L6 Z-bar is 5-13/16th inches.
Old 08-28-2005, 07:27 PM   #8
pritch
pritch's Avatar
Well, my buddy had one up in his boneyard. All fixed and back together. Except I still need that little widget that goes on the clutch end of the push rod. The thing that actually touches the throw out arm. I just put a big flat washer on it for now, but I want the correct part.
'68 Panel
'68 C-10
Ol' Green
Old 08-28-2005, 09:38 PM   #9
hotrodmtodd
'Burban Legend
Pushrod Nut
That's what your widget is called. LMC part # 30-0912. Glad you gotter' back together. Take care, Mike
'69 C-30 dump
'71 4x4 454
'70 Chevelle 427
'71 Cutlass W-31
'71 GTO 400 2x2
Old 08-28-2005, 10:32 PM   #10
shifty
Questionable
shifty's Avatar
I just pulled my 3spd tranny and L6 outta my truck. Please show me a picture of the broken part, I have one to spare.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 08-29-2005, 06:23 PM   #11
shifty
Questionable
shifty's Avatar
PS - where is the little guard that is supposed to prevent outside elements from getting into your bellhousing?
