Old 08-27-2005, 09:06 PM   #1
dcwoodinv
Crossmember probem, on six to eight conversion
Hi all New to the board and love all the great informantion. I am putting a 350/350 in my 72 stepside which was stock with a six. I have my 350 back from the shop and is ready to go in. I pulled the six out today and noticed the tranny crossmember is riveted to the fram and is alot further foward than the one for the auto im putting in. I also noticed the motor mount brackets are further back than the 350. Are these the only differances I will find and how much trouble is it to modify?
Thanks Doug
dcwoodinv is offline   Reply With Quote
Old 08-27-2005, 09:11 PM   #2
krue
Designated A-hole!
krue's Avatar
You need a crossmember for the auto, it bolts in. I hear getting the manual xmember is a pain to get out. The engine mounts are different from the sixes to the eights, but some people opt to mount the sbc in the six position to move the weight to the rear a little.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 08-27-2005, 09:16 PM   #3
Randy70C-10
Randy70C-10's Avatar
I have my 350 in the 6 position, I always thought that they look like they are too far forward in the V-8 position.
Randy70C-10 is offline   Reply With Quote
Old 08-27-2005, 09:35 PM   #4
dcwoodinv
Thats what I was afraid of, looks like I will be doing allot of grinding tonight. I have the crossmember from the parts truck as well as the V8 motor mount brckets but since I will have to have a driveline built I may just set it in the six position.
Doug
Old 08-27-2005, 11:24 PM   #5
shifty
Questionable
shifty's Avatar
can someone tell me what the hell those little rounded things are and how to most easily remove them? i noticed the exhaust bungs, xmembers and everything else on my frame is installed with those things. what kind of hardware is recommended to put in the place of those things?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 08-27-2005, 11:40 PM   #6
dcwoodinv
The look like steel rivits to me, I am going to just drind them off.
Old 08-28-2005, 01:01 AM   #7
kelsfine69
18 Till I Die
kelsfine69's Avatar
Drill a hole thru them as big as you can without wrecking the metal frame hole then take a air hammer and knock the head off, then punch the rivet out. Buy the time you get the last one out you wil be a expert
If you put the proper engine mount in and the trans mount in the proper holes then you dont have to custom build a driveshaft, any wrecker will do.
kelsfine69 is offline   Reply With Quote
Old 08-28-2005, 01:12 AM   #8
dcwoodinv
Thanks for all the help...Anybody have a driveshaft for a shortbed stepside with a TH350?
Old 08-28-2005, 02:23 AM   #9
Green Machine
Green Machine's Avatar
Took me about 1/2 hour per rivot to grind them off on my V8 swap. I put it in the forward position, but I have a clutch linkage and floor shift to properly locate.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 08-28-2005, 10:15 AM   #10
FormerMember
took me about 20 mins a side.
FormerMember is offline   Reply With Quote
Old 08-28-2005, 02:17 PM   #11
shifty
Questionable
shifty's Avatar
i have no use for my driveshaft right now, but i dunno if it will fit. i'm going to try and have my current driveshaft shortened. it's from an inline 6 + 3spd.
Old 08-28-2005, 04:07 PM   #12
dcwoodinv
Shifty if it is off a V8 with a 350 auto I would be intrested in it. How much do you want shipping to 87144, Rio Rancho New Mexico.
Doug
Old 08-28-2005, 06:14 PM   #13
shifty
Questionable
shifty's Avatar
It's off a 6cyl.
Old 08-28-2005, 07:55 PM   #14
55chevy
Car Truck Bike Nut
55chevy's Avatar
Faq
This should be a FAQ, or maybe there is one on converting a 6 cyl to a V8?
Snow free Florida panhandle, don't miss Indiana winters
Temp in Suffolk Virginia, Sentenced 2 to 5 years LOL
68 shortfleet project
94 3500 TD dually
so many cars so little time
72 K2 CST 2WD Blazer
55chevy is offline   Reply With Quote
Old 08-28-2005, 08:56 PM   #15
guyryan100
guyryan100's Avatar
If you put motor in the forward (v8) position, you will need different engine towers. The I6 towers will work on your V8 only in the I6 position.
guyryan100 is offline   Reply With Quote
Old 08-28-2005, 09:57 PM   #16
dcwoodinv
I have both sets of towers it's just a matter of preference I suppose. I f I can find a stock driveline I will move it foward if not then I will keep it to the rear since I will have to have a driveline built anyway.
Old 08-29-2005, 01:21 AM   #17
Cheesewagon
Cheesewagon's Avatar
dcwoodinv I sent you a PM on a driveshaft. Latter Tom
'91 suburban 350 TBI - R 700 4 new daily driver
'72 Cheyenne Super 49,000miles 350/350 frame up resto w/ matching numbers.
Cheesewagon is offline   Reply With Quote
Old 08-29-2005, 08:03 AM   #18
dcwoodinv
ttt
Old 08-29-2005, 01:45 PM   #19
68Stepbed
68Stepbed's Avatar
My driveshaft fit right in with all the V8 mounts and a long tail shaft TH350. It wouldn't have fit with a short tail shaft tranny.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 08-29-2005, 01:49 PM   #20
Joe67
67 is sold
I plan to run a V8 in my 1972 chassis. I saved the auto trans crossmember from my '67 chassis (6 cyl / 2 speed powerglide).
Can I use this crossmember in my '72 chassis with either a BBC or SBC & a 350 auto trans?
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 08-29-2005, 09:59 PM   #21
dcwoodinv
"Quote' My driveshaft fit right in with all the V8 mounts and a long tail shaft TH350. It wouldn't have fit with a short tail shaft tranny.
68STEPBED,
Did your six have a standard or a auto tranny. And if it was an auto did you use the foward or rear mounting position?
Doug
