Old 08-27-2005, 09:18 PM   #1
82c10
needin' money
would it work
would a 73-87 chevy rearend work on a 60-66, also what does it take to upgrade the front end, can you use front end parts off of a 73-87
SWB Stands for Short Wide Bed
82c10 is offline   Reply With Quote
Old 08-27-2005, 09:44 PM   #2
chevy283
chevy283's Avatar
a 73-89 rear has leaf springs and a 60-66 has coil spring im having my 65 rear redrilled to a 5 lug the front crossmember will work just drill 4 holes.
65 c10 tore apart
70 c10 305/350th
chevy283 is offline   Reply With Quote
Old 08-27-2005, 10:59 PM   #3
Mongo
YES_____NO
Mongo's Avatar
sigh...... Why must everyone insist on changing the cross-member too?
If you want front disk brakes just swap out the upper and lower control arms with the spindles attached.Then run the appropriate brake lines master cylinder and proportioning valve. It will save you hell a lot of time and headache. .
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown
Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984
Help support the board
Mongo is offline   Reply With Quote
Old 08-28-2005, 07:44 PM   #4
zenish
brothers and early classic sells kits to change your rearend.be aware the 71 and later are 1.5" wider.
1964 c10 short step
1962 econoline van
1989 rs camaro
2006 yamaha vino 125
1975 goldwing
zenish is offline   Reply With Quote
Old 08-28-2005, 10:32 PM   #5
mbgmike
How much does it cost to have the rear axles re-drilled to 5 lug? I've been thinking about doing that?
mbgmike is offline   Reply With Quote
Old 08-28-2005, 11:08 PM   #6
chevy283
chevy283's Avatar
It's costing me $80.00 for the rear axles.
65 c10 tore apart
70 c10 305/350th
