Old 08-28-2005, 04:56 PM   #1
5150
C10 Club Tennessee
5150's Avatar
Tie Rod End ??????'s
Hey guys,
I am replacing my tie rod ends and when I took the old ones out I counted the turns so I would know how far to put the new ones back in. Is this the correct way to do it or will an alignment shop help a little more.
Bryan
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 08-28-2005, 05:01 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
That would work IF they have the same # of threads, and the end is the same diameter and the rod was not worn.
The best way to get it close, is to measude from zerk fitting on the inner, to the zerk fitting on the outer rod end, then when you install the new one, measure it to the exact same length.
Even in doing this, you'll still need to go get it done properly...and the wider the tires, the more important it is to have it done right.
Old 08-28-2005, 05:15 PM   #3
5150
C10 Club Tennessee
5150's Avatar
Will an alignment shop do it properly? I have a lot of play in my steering and I thought maybe that I needed to screw them in a little more.
Bryan
www.gmtruckshow.com
Old 08-28-2005, 07:15 PM   #4
Longhorn Man
Screwing them in more will do nothing for your steering.
With your truck on the ground, (or rolled onto some 2x4 ends or bricks since yours is so low) have some one in thr truck wiggle the wheel back and forth in the freeplay zone (engine off) while you lay under the grond looking for what is sloppy. If none of the joints buckle up and down or anything, then look at the steering shaft going into the sttering box, and see if the pitman arm moved instantly or if there seems to be some play in the box.
My observations (and I don't know if this matters on your rig) the non power assist gear boxes in these trucks are junk. They always have 1/4 turn or more freeplay.
