Old 08-28-2005, 07:28 PM   #1
red86chevy
Transmission leak Please help
Ok here is my problem... After lowering my '86 2" in the rear only I developed a transmission leak. (dont know if lowering had anything to do with it or not)
It is a th350 (non lock up... I took it out and built a regular th350 for it about 6 months ago). It is leaking out of the yolk. There is a little hole in the middle of the yolk where it slides up into the transmission. The fluid is running out of this hole, running down the u-joint and dripping off. The seal itself is not leaking at all. What would cause this? I built the tranny myself with some help. It probably only has about 800 miles on it. Should there be this much fluid in the tailshaft housing? What would allow this to happen. It has been leak free until now. It is a pretty steady drip...drip...drip...drip even while sitting still.
Thanks for any help
Jeremy
86 c-10 383 w/ sportsman II heads comp 286h cam Edlbrock RPM Performer intake Holley 750 th350 w/2400 stall 3.73 gears with powertrax No-Slip posi unit. Just broken in good. Will get a 1/4 time this week.
red86chevy is offline   Reply With Quote
