Successful Projects-what a concept!!
Got ambitious today and cleaned out the heater box on the 70. 4 deadmice and a bushel of mousenest later, I have air blowing out where it is supposed to. Then I got really brave and installed the OE radio and speaker set-up I found. After removing the defrost hoses, the heater controls and the ashtray bracket the radio finally went in. Don't know if I put the speaker in the right place, but the holes lined up, so on it went.
Yup, I belive that's the stock speaker location if you don't have the speaker hole in the dash as aparently some have. Looks good.
'71 ![]() "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
SKINNY TIRES RULE!
heat coming out of the heater is always nice! Are you going to get rid of the ammo-box/stereo compartment, or just have the ability to listen to AM & FM at the same time
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
#4 | |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Completed projects are always nice ... What is the big metal strap bolted to the dash???
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#6 | |
![]() Join Date: Feb 2005
Hey,when you find that Y adapter for the antenna let me know where you got it. I need a couple of them for my trucks with hidden radios. The stock radios make great decoys and look great in the dash...be nice to have them be functional also.
'69 3/4 ton 427 CST Pickup '71 CST Blazer '72 GMC 3/4 4x4 |
#8 | |
http://www.audio-discounters.com/40-uv44.html
Metra 40-uv44 motorola-type antenna Y-splitter for 2 radios. "Google" it and you'll find places with all sorts of adapters. Couldn't find that type of splitter at the "SellOut" Radioshack. That store severely sucks now.
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
