go bucks!
anybody out there runnin' an "h" or an "x",type cross-over pipe in thier exhaust sys.? i would like to run the x as the research shows better flow,kinda like mandrel bends in the exhaust tubing makes better flow.my thoughts are that if i go w/ the x type sys.won't that make the two sections of tubing come together thus making a ugly sight from the side?(i hate when you can see the tubing showing from a side angle,just my opinion.)i would think the h type would only need to be bent in the middle and keep the tubing up inside the running lines of the frame-rails. where does the h or x cross-over at to get minimal amt. of pipe showing? what you guy's got?
------------------ '68 swb 350/350 w/edelbrock total performance-performer pkg.headers,flowmstrs.no rust of the mid-west on this one!
'68 swb 1/2t 350/350th '86 lngbd 3/4 TON parts getter '49 gmc 1/2 t 5 window 350/350th '96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know? |
go bucks!
ttt
H-pipe is the most common and the easies to do. An X-pipe needs to cross over just behind the end of the trans. You might get better performance out of an X-pipe but only past 5000 rpm. The H-pipe does well for a street truck that your not drag racing all the time. You would really need to build one hell of a motor to notice any differance between the 2 on the street.
------------------ 71 basic C-10 350. The only option is the rust.No nothing on it, but thats all about to change. <A HREF="http://www.geocities.com/stevemau/slam33page.html?1004806705410 " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A>
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
go bucks!
appreciate it slam i was wonderin' the perf. gains between the two. is the h pipe noticeable w/the side angle view.cant be havin' the exhaust work show.pet peeve,i guess!
Senior Moment
![]() Join Date: Mar 2002
I have an H pipe on my 70 and you cant see any pipe any where unless your on your belly.
The sound is better I think ------------------ Steve's 70 CST Soon to have a BB www.picturetrail.com/70CST
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
I have my H pipe located just behind the trans crossmember,& it does not show from the side(straight shot between the ex pipes). you have to be laying on the ground to see it. The X pipe is a better set up,but much harder to install,& as Slam 33 posted,probably not a big diff between the X or H .......unless you are racing. 69 longhorn.
http://community.webshots.com/user/hotrodhorn |
you'll get a slight torque increase with either but I belive you will get a mellower tone with the H-pipe
go bucks!
thanks guy's!just called the guy tonite and scheduled a day this next week to bring it over. he was asking me about what i was bringing over to him and i told him my swb.'68 chevy truck. he said that the rear trailing arms(or wishbone rear-end)trucks are harder to hide the bigger 2.5" tubing and that you have to go under it.....?how do you guy's have your's run?if you remember w/a shrtbd. there is no rear carrier bearing,and i believe my old truck that i once had (a'69 1/2 ton lngbd.) had holes on either side of the carrier bearing cross-member to run the exhaust through from the factory. correct me if i'm wrong.
creator of kong
If you have a big cam.......how does that change the sound of it ? Does it change the way the idle sounds, since your mixing both pipes? Just curious
go bucks!
stock profile 350 cam w/900-1100 rpm torque con. "stock profile cam": 204'-214' w/ .447" lift. not a thumper cam, but a cruiser cam. 1500=5500 effective rpm range.
------------------ '68 swb 350/350 w/edelbrock total performance-performer pkg.ceramic headers,2.5" delta-flow 40 series flowmstrs.no rust of the notorious mid-west on this one!
BUXMAN66, To the best of my knowledge the factory crossmembers have no holes and the exhaust was routed underneath. Here are a couple links to a really nice exhaust installation but it doesn't appear to have any crossover. I think this is the type of installation your wanting but it requires some fabrication and modification of the crossmembers. It might help spark some ideas. www.earlyclassic.com/ctmar2001pg2.html www.earlyclassic.com/ctmar2001pg3.html
72 SWB parts and pieces Oklahoma |
