Old 08-28-2005, 11:17 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Tranny cooler question
Anyone here mount a tranny cooler any place other than in front of the radiator I would like to mount it under the cab or bed area? Any thoughts on this??? BTW I bought a B@M SUPER COOLER 70268 for a 13,000 btu..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 08-29-2005, 12:00 AM   #2
rage'nrat638
rage'nrat638's Avatar
well the cooler needs to have air pass thru it......
unless it has a fan mounted on it.......in front of the rad... or a/c cond...
would give you max cooling........i run two on my 85.....one up front one lower
with a fan mounted cooler......5200 stall heat's up......big time......
a trans brake sends the temp thru the roof.......just IMO
rage'nrat638 is offline   Reply With Quote
Old 08-29-2005, 12:22 AM   #3
lngbed71
Nothing fits but the oil
lngbed71's Avatar
I have an in-the-frame rail cooler for my TH350, works great, can't see it either.
Land of the free
Because of the brave
lngbed71 is offline   Reply With Quote
Old 08-29-2005, 07:00 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
I don't have anything fancy just a th400 with a kit in it..... Guess I will look fo a little e-fan to stick on it ... Thanks guy's..
MEMBER #6377
Project "7DEUCE"
Old 08-29-2005, 07:03 PM   #5
kelsfine69
18 Till I Die
kelsfine69's Avatar
You can buy remote trans cooler w/fan and they can be mounted behind the cab up under the bed...... seen it done looks good .
kelsfine69 is offline   Reply With Quote
Old 08-29-2005, 07:39 PM   #6
cdowns
cdowns's Avatar
they make a heat sink cas aluminum frame rial mounted tranny cooler ,they work well and don't require a fan//
Old 08-29-2005, 09:48 PM   #7
kelsfine69
18 Till I Die
kelsfine69's Avatar
found this...http://www.flex-a-lite.com/auto/html/remote-mount.html
