Old 08-28-2005, 11:35 PM   #1
garthdader
shackle flip kit vs. rear spring
I am sure I am not the only one here with lift blocks. I have a 6 in lift and I am contemplating on which way I want to go. Go with the 5 1/2 in springs from skyjacker, superlift etc., or I also rear about a shackle flip kit from ORD that is equal to 4 inches, then get a 2 in spring. If cost wasnt a factor, which would be a better in the long run? Since I am removing the blocks, am I going to have to worry about pinion angle or driveshaft length. It should be the same after i change it....right?
1971 Chevy 6" superlift 35" xterrains 350 VORTEC crate
garthdader is offline   Reply With Quote
Old 08-29-2005, 05:25 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Goto offroaddesign.com and read about what they say. Basically, your rotating the rear of the stock spring down, pivioting on the front of the rear spring so it tends to move the tire forward and the pinion up . on long wheel base trucks this is a problem and the axle would have to be degreed down w/ a shim or smaller lift block installed backwards to get the pinion angle inline. The shackle flip would be cheaper than buying new rear springs outright.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 08-29-2005, 08:01 AM   #3
Are you looking for 6"s?The shackle-flips come in 2" and 4".You could use 2" flip/4" springs or visa-versa.The combination almost doubles the cost.I bought 6" springs because the truck I was lifting had a broken leaf on each side and figured the springs were pretty fatigued.I bought a complete f/r kit from TuffCountry.They supply a t-case drop.These can be purchased seperately.One another truck with good springs,I bought a 4" flip and 2" tapered blocks from ORD to get 6".Another option to avoid blocks would have been to use Add-a-leafs.This offers no angle compensation,though and I don`t think 2" blocks are a bad thing.There are traction bars for axle wrap and with no blocks there`s still wrap with leafs,big tires,and hp.
Old 08-29-2005, 09:02 AM   #4
highrpm
Springs
Did you buy the Tuff county EZ rides or heavy duty springs and whats your opinion of the ride.
highrpm is offline   Reply With Quote
Old 08-29-2005, 10:10 AM   #5
Musclerodz
If you want to maintain ride quality out back, go with the flip kit and a 2" block.
Mike
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 08-29-2005, 03:27 PM   #6
Prerunner1982
Prerunner1982's Avatar
it also depends on what you use the truck for, the rear flip will tend to give more flex.. not what you really want for a mud truck...
on a side note.. welcome musclerodz.. suprisingly enough i know where washington is...unfortunately..
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 08-29-2005, 05:42 PM   #7
Musclerodz
Is that good or bad? For a DD I would go with the flip. If you are doing a lot of offroading, you might want something stiffer.
Mike
Mike Redpath
Old 08-29-2005, 10:09 PM   #8
I got the EZ-Rides.They ride better than stock.I`m using Rancho 9000RSX adjustable shocks.I can set them soft for flex and smooth rides.Set on stiff,they handle weight very well.
Old 08-29-2005, 11:12 PM   #9
garthdader
Thanks guys...lots of options. I am going to a kind of all purpose trail rig. somewhere in the middle of rock crawler and mudder.
Old 08-30-2005, 03:06 AM   #10
SERE
"AIRBORNE"
SERE's Avatar
ORD flip
I did the shackle flip on my 3/4 ton and got 5 1/2 inches of lift. I put 4 inch spring packs on the front. So, I had to take the factory 1 inch block out of the back to even it up. I am running 35's no problem. Did not notice any difference in the ride from the springs. Just more flex and some cushion from the bigger radials....Mine is LWB and I haven't had any pinion angle problems with the one piece drive shaft.
69 GMC 2500 4X4 long stepside 454 BB
SERE is offline   Reply With Quote
Old 08-30-2005, 02:08 PM   #11
1972
Majician
1972's Avatar
Check out the new shackle flip at http://diy4x.com/suspension.htm It's real beefy and you can easily make any length shackle you need out of flat stock so you can get rid of the cheesy factory shackles.
1972 is offline   Reply With Quote
Old 08-31-2005, 08:05 AM   #12
1969K10
1969K10's Avatar
Thanks for the post guys!!! i've been debating what I want to do to level my truck out... the rear sits lower than the front... i'm still wondering about lengthening the rear shackles vs lift blocks... either way it'll be temparary, i've decided the truck needs about 4" of lift... then i'll go with shackle flip, and see what i need from there...
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
