Old 08-29-2005, 10:38 AM   #1
TimS37
Question 51 Chevy Truck Rearend Swap?
I want to swap out the original 6-lug rearend for a 5-lug rearend. I'm planning to put 15" rims (8" dp.) and am concerned about the width of the new rearend being to wide. I'm also putting a new parallel leaf spring suspension kit on it. Currently, I have a '80 chevy truck posi rear which is very close to the same width as the original rear but the truck has the original ride height. The new rear suspension kit will lower the ride height, so I need a rearend that will allow the wheels to fit into the wheel wells. Does anyone know what year and type of rearend would work for my situation? I've been told 10-bolt chevy rearends but not specific ones. Does anyone know?
TimS37 is offline   Reply With Quote
Old 08-31-2005, 01:07 PM   #2
Phat
I think the rear you have is about 61 ish and 60 works out fine. I have the 82 six lug 4x4 rear in mine and its on air so its low no tire rub . Measure axle flange to axle flange(easy with the drums off and a couple straight edges)
Phat is offline   Reply With Quote
Old 08-31-2005, 02:35 PM   #3
TimS37
Thanks for the information. I'll check that measurement. I appreciate your help!!!!
Old 09-18-2005, 09:08 PM   #4
solidaxel
solidaxel's Avatar
I used a 75 Camaro and moved it back 3/4 " and am running 255/ 70 15 BFG on my 55 1st series and no mods to the frame or fenders
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
