Old 08-29-2005, 09:07 PM   #1
David Johnson
David Johnson's Avatar
footwell patches?
Can you buy footwell patch panels? How about toe pans? I need them for a 66 custom cab I'm trying to rebuild. I have looked at every vender I know of and can't find them. If you can't buy patches, does anyone have any good pieces they could cut out of an original cab?
David Johnson is offline   Reply With Quote
Old 08-29-2005, 09:26 PM   #2
66+81
66+81's Avatar
What, like in the floor?
1966 Chevy C10 longbed stepside 350/350
1981 Chevy Custom Deluxe C10 short fleet 305/350
66+81 is offline   Reply With Quote
Old 08-29-2005, 09:39 PM   #3
David Johnson
What I mean are the footwells, the side panels on the inside of the cab where the air vents are, and the toe pans, the floor pans that start at the firewall and come back about 18" or so and join the the front floor pans. i only need about 6" or so of the footwell from the floor up. I'm sure that is all about as clear as mud.
Old 08-29-2005, 09:46 PM   #4
66+81
66+81's Avatar
Check Chevy Duty. LMC might carry them, but I don't think so. Not sure of either of the web sites, but you should be able to type it in your search bar.
Old 08-29-2005, 10:35 PM   #5
64fleetside
I used 67-72 kick panels patches & made them work, from what I understand that's the best you can do. Brian
64fleetside is offline   Reply With Quote
Old 08-29-2005, 11:40 PM   #6
David Johnson
That's what I was afraid of, how did they turn out?
Old 08-29-2005, 11:47 PM   #7
ozzyracing
Where could one find floor panels for a 65 GMC? I mainly need the area over/around the tranny.
65 SWB 454 350T
ozzyracing is offline   Reply With Quote
Old 08-29-2005, 11:56 PM   #8
David Johnson
I think GMCPauls has them. I just ordered evrything from the bottom of the doors down from them. I hope it all fits good.
Old 08-30-2005, 01:35 PM   #9
64fleetside
They turnde out fine, you just lose the funny "dent" down there, the 67-72s are straight. Brian
Old 08-31-2005, 10:59 AM   #10
coilspring66
Kick panel patches
I fabricated my own. If you think about it, there are no real complicated bends or anything. You can get the appropriate sheet metal from Lowes, for real cheap. I just used my vise, hammer, tinsnips & pliers to do what few bends I needed. The most you can lose, if you fail (which you probably will not), is $5 or so. If you're going to start rebuilding all of that stuff down there, you're going to have to get a feel for creative patching, even if you do get preformed patch panels. I found that they are (with the exception of the ones with complicated bends, such as rocker panels) more trouble than what they are worth. Try it, you might surprise yourself.
coilspring66 is offline   Reply With Quote
