Old 08-29-2005, 09:36 PM   #1
cornutz
All Praise RANDY!!
cornutz's Avatar
BBC oil pump on SBC???
Ok,
I saw this in the "pay it forward" thread... what all is involved with this? What length pick up tube do you use? I know it has to be for a BBC oil pump, but again, what length.
any help with this would really help!
Thanks all!
NutZ
cornutz is offline   Reply With Quote
Old 08-29-2005, 11:06 PM   #2
cornutz
All Praise RANDY!!
cornutz's Avatar
anybody?
Old 08-30-2005, 12:56 AM   #3
junkyardjohn
junkyardjohn's Avatar
I'M NOT SURE ABOUT OIL PUMPS, BUT REPLACING SMALL BLOCK WATER PUMPS WITH STOCK BIG BLOCK WATER PUMPS IS THE SH!TS. THEY FLOW LIKE NO TOMORROW. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 08-30-2005, 01:56 AM   #4
GenIIIShorty
JUNK COLLECTOR!!!!!
GenIIIShorty's Avatar
i've been told a big block oil pump on a small block will give you too much pressure, and you should probably just go with a high volume small block pump, it'll give you plenty. just my .02
baby
The dark side! 2000 XLT PSD F-250 4x4! Offroad package
1970 C10 Short-step soon to be short fleet, maybe? Corvette in truck's clothing in work! Corvette IFS, IRS, TPI and Doug Nash 4+3
GenIIIShorty is offline   Reply With Quote
Old 08-30-2005, 09:58 AM   #5
stllookn
Saving 1 truck at a time!
stllookn's Avatar
cornutz, there is a very long and detailed article on oil pumps for small block Chevy's in How to Build Max Performance Chevy Small Blocks on a Budget by David Vizard. Too much pressure and volume is as bad as too little. The stock pump is fine for 350-375 hp and 6500-6750 rpm. There are some mods to increase the performance of your existing pump by lapping the sides and grinding some small relief passages. The article also discusses installing a big block pump for extra volume, if needed. He spends considerable time on this subject and I can't condense it here. Knowing how you intend to run your engine will help you make an educated decision. You will come away from this exercise a small block oil pump expert compared to your friends!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 08-30-2005, 02:28 PM   #6
4x4Poet
I've often posted about Melling's improved pump design:
http://store.summitracing.com/defaul...part=MEL-10552
Only 10% increase over oem with superior design features and, I would expect, better longevity. Bolt on pickup (no welding needed), longer gear teeth, stronger cover, better supported shaft, etc.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 08-30-2005, 04:46 PM   #7
acloco
Big block pump on a small block does not give too much pressure.
I ran a 350 for over 45,000 miles...with no problems (sold the car).
acloco is offline   Reply With Quote
Old 08-30-2005, 04:47 PM   #8
acloco
Also..if you are rebuilding any Chevrolet V8 or installing a high volume pump....please spend the $10 or $15...and buy a heavy duty oil pump drive shaft!
