R.I.P. E.S.L.L.
![]() ![]() Join Date: Aug 2005
I know it seems like a stupid question, but a buddy of mine offered to give me a free 400 C.I. "small block". I was planning on putting in a 350 mostly because there is no other engine that parts are more available for. I mean really, what's easier to find parts for. but can I use 350 parts on a 400, if they are both small blocks, It would be great to get a free motor, but if it is going to be a problem getting parts, then i want to know. It was pulled from a running truck, so it runs but it need to be rebuilt. Is it worth haulin home and going through ???? I would of asked my friend, but I didn't want to seem like an ingrate.
1971 Custom C/20 ![]() 1970 CST 20 1970 C/30 Flatbed 1983 C/30 Dually 2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350. R.I.P. El Jay R.I.P Jessie. R.I.P Grumpy. Every day is a gift from God. |
Saving 1 truck at a time!
You're right...I will take the small block 400!!!!!!! Actually the small block 400 is very similar to and uses all the same parts as a 350 except the block, crank and external balancer. If you put a 400 crank in your 350 you end up with a 383. Take it...that motor rocks...DUDE and has more torque and hp than a 350. Just tell everyone it's just a 350 after you smoke'm.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
blood type; Retumbo
or.......put the 327 crank in the 400 after you bore it out .040. then you will have a 351 with a VERY high rev limit. I know a guy who has one with roller cam bearings (yes, I said bearings) & his power band starts about 6000.
for future reference here is the displacements offered in small block form from GM. 262, 265, 267, 283, 327, 350, 400. parts from all will interchange except for valve covers from pre 1957. the early ones have a little different bolt pattern. pre 1968 (I think) crankshafts have a smaller main bearing journal. after that they went to a 2.10 main journal. the 400 has "steam" holes drilled in the heads and block between the middle cylinders. in short I would take it. after all its free!!
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
Watch out for your cornhole !
![]() Join Date: Jun 2003
68C15, you forgot a few....
it's 262, 265, 267, 283, 302, 305, 307, 327, 350, and 400. There are 10 different displacement sizes of small block Chevys.
Working on a Nova.
Also you have to remember you can change displacement by swapping crank's or over boring the cylinders. Some popular numbers are the 335, 355, 377, and 383, but this is not an all inclusive list the posibilities are almost endless with the Small block chevy. Also using after market blocks I believe they are up to a reliable 427 CID small block chevy engine and if reliability is not the issue you can even go a little higher. This is what I love about the Small Block Chevy. The Big Blocks have pretty much the same interchangeability and again lots of different numbers can be produced. The 400 block is an excellent base. If you plan on building an engine that goes over 500 HP you may want to change it to a 4-bolt main and add the extra external cooling system plumbing that runs between the block and heads. Other wise 400 sbc engines are great since it is cheaper and easier to build an engine that has horsepower numbers less than or equal to its Cubic Inches, but once you start asking for more horsepower than you have Cubic Inches it starts to get expensive with a lot more research required.
Java Mechanic
What's funny is that we always call the 400 a "400 small block" as if the distinction was required.
There is no, despite some Chevrolet badging that argues differently, 400 big block. The closest chevy engine is the 396. Anything labeled "400" with a big block is actually an Oldsmobile or Buick. (Oldsmobile and Buick actauly *do* have small and big block 400s)
Keith 11 Lincoln MKT -- Momma's wagon ![]() 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
#7 | |
User #12137
![]() Join Date: Apr 2004
The 400 emblem on trucks denotes the 402 big block.Once displacement was increased,SS396s were actually 402s.
The factory 400 small block can be built to 406 and 426 with some cutting.
#9 | |
#10 | |
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
#11 | |
Java Mechanic
#12 | |
Java Mechanic
http://en.wikipedia.org/wiki/Chevrolet_V8_engine There was a 4.3l in 1075 (262) , the 4.4l (267) was used in 1979 in A body cars. I hadn't known about these either. I had thought all of the rinky-dink v8s were variants of the 305 until the new engine family came out in the 90s.
#13 |
R.I.P. E.S.L.L.
Well it looks like I'll have to clear some space in the garage..
#14 | |
Seasonal Poster
67 GMC Short Step 350/4-Speed/3.08 Posi Front/Rear Sway Bars Kelowna BC, Canada Member of DTPW |
#15 |
senior member
so a 396 is a small block for some weird reason i always thought it was a big block i dunno y
69 GMC bagged |
#16 |
The 400 tag on big blocks intended to obscure for insurance reasons in the early 70's. By that time, ALL of the insurance companies knew wht 426, 427, 440, & 454 meant.
I have never heard why GM built 396 engines that were actually 402 cubes.....we may never know. |
#17 |
Working on a Nova.
They were trying to make up for the initial horse power loses due to the change from closed cumbustion chambers to open cumbustion chambers by adding hidden Cubic Inches with the least amount of design change as possible. Radical design changes cost big bucks. It was later determined that the open combustion chamber could produce more horse power, but they did not have time to do the initial research due to the emmision changes. The big question is why did they get rid of the "W" heads that the 348 and 409 used?
#18 |
blood type; Retumbo
chevy made two 262 engines. the first was a V8 while the second was a V6. the V6 was basically a 305 with two of the middle cylinders left out. it makes for a real shaker. that's why it has a balance shaft in the later versions.
#19 |
gloryhound...the W head question is easy....LOTS better flow with the individual ports and taller head (overall) of the "porcupine" heads.
#20 | |
#21 | ||
Java Mechanic
I hear you... I test drove a Corolla tonight that has more power than that in an engine about the size of a sewing machine. lol (Hey -- take it easy.. if you drove 63 miles to work, one way, you wold want at lest one econo car too! lol) Quote:
I grew up on bowties and was shocked to learn that you couldn't just snatch the heads off of a 340 and stick them on a 318. ![]()
#22 |
Have the 400 SBC block checked out before getting any parts (pistons, rings, etc.), 0.030 to 0.040 is about the safest overbore you can go if you plan on any performance upgrades in the future. If it is to remain bone stock, you may get a 0.060 overbore. There are 400's out there running a 0.060 overbore, but there a lot more that are boat anchors after the cylinder walls cracked. 400 blocks have what they call siemesed cylinder walls to strenghen the area between the cylinders, which basically means there is less metal between the cylinders, so max overbores typical on a 350 are out. 400's are more expensive to rebuild than the 350, but the added torque is worth the money. In addition, both the harmonic balancer and the flexplate (auto trans) is unique to the SBC 400, as the engine, from the factory, is externally balanced, as opposed to all other factory SBC's, which are internally balanced.
400 heads also have 'steam' holes in them. I've heard you can use 350 heads and drill out the holes using a 400 head gasket as a template. I've heard conflicting information on the necessity of the steam holes, but I guess if Chevy didn't think they were necessary, they wouldn't have put them there in the first place. These are great engines, and in stock form, don't rev up like a 350, but the increased torque is seat of the pants fun. At the worst, if the block is toast, you still have the crank to turn down to make a 383.
'67 1/2 Ton Short Bed / 396 cid / AC w-R134a / 5 Lug Leaf spring rear axel / 5 Lug Frt Disk Brake Conversion '97 Trans Am - Black / LT-1 / K&N FIPK Cold Air Kit / Hooker Cat-Back Exhaust / 160 Thermostat '02 Buick Regal GS / Bone Stock Last edited by GasHog396; 08-31-2005 at 12:32 PM. |
#23 | |
#24 | ||
Java Mechanic
My favorite is slightly obscure.. lol Quote:
#25 | |
its all about the +6 inches
There are many stories on why the 396 gre 30 over into a 402, some are purely stupid, and others kinda make some sence. The one i tend to believe, Chevy did not want a small block to be bigger than there small big block. So, when the 400 small block was introduced in 1970, they bumped up the cubes on there baby big block.
Why play with a 472 when a 500 is there for the pickin? Quote:
