Wiring help
I'm putting in that keyless entry system, where i'm putting the box for the system doesn't let the wiring harness reach. I was going to get some wire, but the wire has some sort of metric measurements. I don't know much about the guage numbers, but on the wires have 0.5mm^2 (millimeters squared) and one the hot wire it has 0.75mm^2. How can I figure out what this is in a guage measurement. Also, if I have to use a bigger wire than what comes with the kit will that hurt anything?
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
huh?
![]() Join Date: May 2000
I don't see anything at all wrong with running bigger wire. You should have no problems at all with doing that. As far as the wire sizing, go here:
http://www.ilsco.com/IlscoHome/ilsco...edia/wire.html TJ
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
I agree with 68 stepside with larger wires you can not go wrong just dont go smaller.
1968 GMC CST long wide box http://groups.yahoo.com/group/67-72-collectors/ |
its all about the +6 inches
Agreed, anthough, you could go too big and increase the resistance.
Just buy some thicker whire, as long as it isn't a huge battery cable or something...you'll be ok. |
English Chevy Owner
A great tool for me as I need to go the other way. All my truck manuals have wire sizes in AWG and living in the UK means that I have to buy wires in metric... blooming marvelous!
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
