Old 08-30-2005, 04:41 PM   #1
zachary2001
Lowering Blocks
I Heard On Here Somewhere That You Can Use A Lowering Block On A Trailing Arm Rear End, If This Is True I Would Be Interested In A Set For My Truck If Anyone Can Give Me Any Information I Would Appreciate It...
zachary2001 is offline   Reply With Quote
Old 08-30-2005, 05:40 PM   #2
72BLAZERDUDE
72BLAZERDUDE's Avatar
You can use up to a 2 inch lowering block on trailing arm suspension. Anything bigger and the u-bolts start getting real close to the ground. There are quite a few vendors that have them. I think GMC Pauls carries a set. If not I will find out where my son got his. Just make sure you dont get ones for a leaf spring truck, they wont fit.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 08-30-2005, 05:43 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I build them out of 2x3 thick wall tubing. There are pictures on here of a set I built if you care to search them out.
Old 08-30-2005, 06:34 PM   #4
tnblazerk5
User #12137
tnblazerk5's Avatar
i put 4 inch ones on my 67 and they drag sum so i wouldnt go that low
tnblazerk5 is offline   Reply With Quote
Old 08-30-2005, 07:35 PM   #5
pissonNOS
senior member
pissonNOS's Avatar
heres the ones i built there cheap to build only cost me about 10 bucks
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 08-30-2005, 08:02 PM   #6
tnblazerk5
User #12137
tnblazerk5's Avatar
those look kinda like the ones i made only i put in holes for the ubolts to go though
and yea there easy to make
Old 08-30-2005, 08:04 PM   #7
pissonNOS
senior member
pissonNOS's Avatar
i took the pic before i drilled the holes
69 GMC bagged
Old 08-31-2005, 09:34 AM   #8
zachary2001
lowering block
what kind of metal did you guys use to make these out of and what were the dimensions of this block.
Old 08-31-2005, 02:30 PM   #9
pissonNOS
senior member
pissonNOS's Avatar
i used 2 inch square tubing and then just made some plates for the ends, and all i did was measure the distance of the U bolts then added an inch on either side thats how long i made em
69 GMC bagged
Old 08-31-2005, 03:16 PM   #10
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
what are the benefits of this over just a drop sping( other than cost or is that it?)
Current Rides:
Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread
EvilK5 - 71 K5 Blazer
Evil Twin - 2006 Suzuki M109R
EvilDmax- 2018 GMC 2500 Denali Duramax
chevyguy_72 is offline   Reply With Quote
Old 08-31-2005, 05:31 PM   #11
dubie
dubie's Avatar
I made sure to save your pic when this was aked before, and here it is
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 08-31-2005, 05:42 PM   #12
tnblazerk5
User #12137
tnblazerk5's Avatar
oh lol sorry about that !
where the holes was in mine i welded in tubing kinda like the trailing arms are done just for extra suport
Old 08-31-2005, 06:14 PM   #13
matthufham
the block instead of a different spring keeps the ride quality stock. it's also more simple to install and cheaper to buy.
matthufham is offline   Reply With Quote
Old 08-31-2005, 06:41 PM   #14
Tx Firefighter
I used them because I had scrap steel and spare time. Total cost is about 30 bucks, of which the longer u-bolts are 25 of that.
Old 08-31-2005, 06:43 PM   #15
Tx Firefighter
Also, don't go over 2 inch drop with blocks. Any further, and the u-bolt and shock will hang below the scrub line, which is dangerous and illegal. In the picture above, the truck has 17 inch wheels and it's still close to hanging under the scrub line. Imagine what it would be like with a smaller diameter wheel or a taller block.
Old 08-31-2005, 07:03 PM   #16
chevyguy_72
Vintage Evil
so what are you guys using to drop the front 1" drop springs?
Current Rides:
Old 08-31-2005, 11:11 PM   #17
Nelson
Lowering blocks... Thats a great idea!!! Did you do anything for the front?
Nelson
1970 C10 350 Auto.
A/C not Working
Nelson is offline   Reply With Quote
Old 09-01-2005, 10:50 AM   #18
Tx Firefighter
Cut 1 coil for a 3 inch drop. Cost is free...
Old 09-01-2005, 11:32 AM   #19
motocrosschump
Couldn't you cut the rear spring also?
2006 Titan SE Crew Cab Daily Driver
2005 Mazda Tribute (Wifes car)
1969 C10 SWB 350/3 Fleet "Max"
1969 Chevelle 2 door 350/3
motocrosschump is offline   Reply With Quote
Old 09-01-2005, 12:43 PM   #20
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
NO ! the rear springs have to be bolted top and bottom with the pigtails !! DO NOT CUT THE REARS !
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 09-01-2005, 02:08 PM   #21
motocrosschump
gotcha..still green but its starting to fade.
Old 09-01-2005, 09:31 PM   #22
mbgmike
I used the trailer hitch reciever draw bar for some little car. they Had them on sale at Walmart just cut off the part the ball went through. they were galvanized and on sale for 1.00 each. I only had to drill one hole in each. I had bought three inch drop springs and wanted to lower it more without buying springs again. now its 4.1/2in
mbgmike is offline   Reply With Quote
