Old 08-30-2005, 05:06 PM   #1
zimmm
Question Transmission Vacuum Line hook up
Hi new to the board and am in need of some information..... imagine that...
72 K20 - 350/350
Where should the vacuum line to the transmission be connected to the motor/carb?
It has an edelbrock carb on it with 3 ports on it. Currently two of the three are used - 1 to oil breather, 1 to dist. vac advance & 3rd is plugged.
I bought the truck recently and this line was not connected and no open connectors that I can see.
thanks
Mike Z
72 K20 - quote upon getting it home "What did you buy it for if the brakes don't work"
98 Z71, 96 Tacoma + more toys than I can remember
zimmm is offline   Reply With Quote
Old 08-30-2005, 05:43 PM   #2
paintpyro
paintpyro's Avatar
Welcome to the board. If you look on the back of the carb by the base, there is a port there.
70 shortbed stepside
"Schleprock"
350 w/TH400
rallys and BFGs
-We can rebuild it, we have the technology-lower,shinier,faster
paintpyro is offline   Reply With Quote
Old 08-30-2005, 08:11 PM   #3
dwaite72lnghrn
If it is a stock intake behind the carb is a tap on the intake where the vacuum canister runs. There is normally a "T" for it there. If you have power brakes the back hole is used. The trans is looking for full vacuum, So front-back bottom hole or the driverside front pipe.
Sorry almost forgot to say WELCOME to the board.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 08-30-2005, 08:30 PM   #4
JimKshortstep4x4
Talking
Here is a pic of the vacuum line hookup, (I made the line but it is similiar to the factory line). The open end of the tee is for the vacuum line to the brake booster.
Jim
Last edited by JimKshortstep4x4; 08-30-2005 at 08:37 PM. Reason: Posted wrong pic!
Old 08-31-2005, 01:34 AM   #5
zimmm
Thanks for all the help. will have to add a T on the manifold, as the vac hose for the brake booster connected there.
