Old 08-30-2005, 09:35 PM   #1
71Dragtruck
71Dragtruck's Avatar
Heater removal
How much of a pain is it to remove the complete heater assembly in a 71 inside and out? Can it be done without removing the inner fender? Any tips before I begin would be thumbs up!
71Dragtruck is offline   Reply With Quote
Old 08-30-2005, 09:39 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
look in teh faq... jewels did this with Pics.
Old 08-30-2005, 09:40 PM   #3
71Dragtruck
Right on thank's, why do people never look there first.
Old 08-30-2005, 11:05 PM   #4
71Dragtruck
Read the FAQ's, would also like to know about pulling out the cab side part, I'm taking it ALL out, is it just bolted in, and will the under hood part come out without removing the hood?
Old 08-31-2005, 01:27 AM   #5
Deuce
Deuce's Avatar
Easier to remove inner fender. Look for my post for"Semi Smooth Firewall" I removed the heater and installed a small industrial heater/fan combo.
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 09-03-2005, 11:08 AM   #6
ac102nv
ac102nv's Avatar
71 dragtruck,
When I removed my heater assy, the inside just unbolted once the glove box insert was removed. Outside w/ inner fender is harder than inside...but I took the front clip off, so that wasn't a problem either.
'72 C10 lwb 454/TH400
ac102nv is offline   Reply With Quote
Old 09-03-2005, 12:21 PM   #7
jakeslim
Premium Level Member
jakeslim's Avatar
drop the inner fender a bit. You don't have to remove it all the way. Takes minutes to do. Saves frustration and headaches.
69 K5 CST stock- 350, 4speed
77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's,
jakeslim is offline   Reply With Quote
Old 09-03-2005, 10:23 PM   #8
71Dragtruck
Thanks, likely going to start tomorrow night.
