08-30-2005, 11:30 PM | #1 |
Got Big Block?
Fuel Cell
Does anyone know if this will fit under our trucks?
http://store.summitracing.com/defaul...15%2DS&FROM=MG Not as nice as what Fuel Cell Guy makes but I may can pick it up fairly cheap. Thanks.
"Experience is what you get when you didn't get what you wanted." Last edited by Purs; 08-30-2005 at 11:34 PM. |
08-31-2005, 09:21 AM | #2 |
Got Big Block?
ttt
"Experience is what you get when you didn't get what you wanted." |
08-31-2005, 10:01 AM | #3 |
Buy one and let me know..that sure does look pretty.
2006 Titan SE Crew Cab Daily Driver 2005 Mazda Tribute (Wifes car) 1969 C10 SWB 350/3 Fleet "Max" 1969 Chevelle 2 door 350/3 |
08-31-2005, 11:42 AM | #4 |
I'd go with yes for $100 Bob!
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
08-31-2005, 01:56 PM | #5 |
I am running a 24x20x10. Cell. I had to get ECE rear crossmember to make it fit. short and simple it was a P.I.T.A.
If you think about the hassle your going to have making brackets and crossmembers its much esier to get one from Fuelcell guy. His tanks are also sloped at the back for ground clearance and depature angles right ? If I was to do it again I would get one thats made to fit unless you paln on putting it in the bed. Then the summit tank would work.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
09-03-2005, 09:48 PM | #6 |
Epoxy Primer Friendly
fuel cell
You could have a crowded bed like mine (older pic) need to take some new ones)
09-03-2005, 10:25 PM | #7 |
blood type; Retumbo
I thought about one of those myself. but how to fill it WITHOUT cutting the floor is a major issue for me. 71swb4x4 has a FCG tank & it works nicely. all I have to do is steal the check book from the wife
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
09-05-2005, 12:30 AM | #8 |
my gas saver
i know you can get the 23x17x11 16 gallons to work.
85' SWB, 4.3/TH350, getting ready for paint 84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black 71`SWB, project ebay feedback |
