Old 08-31-2005, 01:37 AM   #1
Deuce
Deuce's Avatar
Does a OPTIMA Battery(Gell Cell) need to be vented??
I removed my gas tank from behind the seat and did a blazer tank install to achieve a safer system for fuel injection. That being said I want to put the OPTIMA Battery behind the seat so I can make a cold air intake mounted where the battery now sits.
What are my other options for mounting a battery other than in the bed or under the truck on the frame(Blazer tank, stepside box...........for now)
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 08-31-2005, 05:29 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Optimas do not need vented, although, you may still run into NHRA rule problems if mounted in the cab. (Asuming you wanna go to the drags)
Old 08-31-2005, 10:13 AM   #3
motocrosschump
Post pictures when you are done.
2006 Titan SE Crew Cab Daily Driver
2005 Mazda Tribute (Wifes car)
1969 C10 SWB 350/3 Fleet "Max"
1969 Chevelle 2 door 350/3
motocrosschump is offline   Reply With Quote
Old 08-31-2005, 10:28 AM   #4
StingRay
StingRay's Avatar
You could mount a box through the bed or cab floor. It's still an under the truck mounting but would be accessible from the top. We do this in some of our motorhomes as it maintains access and covers any venting issues.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 08-31-2005, 11:41 AM   #5
mocwon
Keep On Truckin'
mocwon's Avatar
You could mount it on the driver's side like I did. Also, the Optima battery is not a gel cell, its still a lead acid battery but it is different technology that doesn't require venting.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 08-31-2005, 12:13 PM   #6
Deuce
Deuce's Avatar
Can you post me a pic of how you mounted your battery please???
Old 08-31-2005, 12:41 PM   #7
mocwon
Keep On Truckin'
mocwon's Avatar
I'll have to get them for home tomorrow but, all I did was modify a passenger side battery tray and bolt it up. GM made an auxillary tray for the driver's side but they are not reproduced. I've seen them sell on the parts board before.
Just Passin' Thru
Old 08-31-2005, 02:47 PM   #8
Deuce
Deuce's Avatar
I thought about the drivers side but I think I want the battery out of the engine compartment all together.
I'm going to try it behind the seat.
Old 08-31-2005, 04:25 PM   #9
gonebad2
Merciless Butcher
gonebad2's Avatar
C-3 Corvettes had them mounted behind the drivers seat on the inside of the car. There was a sealed compartment that covered the battery. In those days, they were using normal lead and acid batteries that required venting. I drove Corvettes for years and never had a problem with the battery because it was mounted inside.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 08-31-2005, 05:26 PM   #10
Fred T
Cantankerous Geezer
Fred T's Avatar
Early VW Beetles had the battery under the back seat. If you got someone heavy enough in the back seat, the springs would short across the battery posts. Tells you how far we have come safety-wise in the last 40 years.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 08-31-2005, 05:45 PM   #11
tnblazerk5
User #12137
tnblazerk5's Avatar
lol i had a bug and that happend to it burnt it to the ground it cought the seat on fire and thats all it took lol latter on i turned the bug into a rail buggy
tnblazerk5 is offline   Reply With Quote
Old 08-31-2005, 11:33 PM   #12
FirstGen
Just Don't Stop!
FirstGen's Avatar
mine is mounted against the frame at the passenger most rear part. You can see the bottom of the battery barely in this picture. I have a red-top. You can actually mount the Optima's any way you want even upside down if you want, they are totally sealed.
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 09-01-2005, 12:06 PM   #13
Deuce
Deuce's Avatar
I'll have to investigate that!!
Old 09-01-2005, 05:07 PM   #14
mocwon
Keep On Truckin'
mocwon's Avatar
He's right... Check out their website
Just Passin' Thru
Old 09-20-2005, 02:02 AM   #15
Racetruck1
Optima batteries are gel-cell and can be mounted in any direction. BUT they are lead-acid batteries and DO have a vent, look at the top of it and you will see a small black disc in the top, venting batteries means letting all of the hydrogen gas out into the atmosphere to prevent an explosion hazard in a confined space. That disc is made of a sintered carbide and is porous. If your battery case is open to the air or has a good sized hole for air to get in or out, you're O.K. If not I would be concerned a bit. I have seen an explosion caused by an Optima battery while being charged up inside of a boat with a sealed box, no one hurt but a bad mess, it was caused by the H gas built up and set off by a spark from a loose term that got bumped. Better safe than sorry!
Racetruck1 is offline   Reply With Quote
Old 09-20-2005, 08:07 AM   #16
djracer
djracer's Avatar
here's how mine was on my 71
this brkt came from a round track magazine
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 09-20-2005, 02:09 PM   #17
bigblock73
yeller
bigblock73's Avatar
Here is what I am using on my '73
http://www.classicperform.com/tech_a...attery-Box.htm
http://www.classicperform.com/battery1.htm
bigblock73 is offline   Reply With Quote
