Old 08-31-2005, 03:24 PM   #1
dennislbrooks
dennislbrooks's Avatar
66 Power Brake Booster
My truck has manual brakes now are there any roadblocks to putting a 66 stock booster on a 66 C10? I noticed that the stock booster has 4 holes for mounting and my truck has only 2 studs now for the master cylinder.
thanks
dennislbrooks is offline   Reply With Quote
Old 08-31-2005, 05:17 PM   #2
64fleetside
Its a bolt in but you need the brackets, there is an aluminum bracket thqt bolts to the firewall & also a steel bracket w/a lever setup. Brian
64fleetside is offline   Reply With Quote
Old 09-01-2005, 09:36 PM   #3
zenish
where did you find a 66 booster?i need one.
1964 c10 short step
1962 econoline van
1989 rs camaro
2006 yamaha vino 125
1975 goldwing
zenish is offline   Reply With Quote
Old 09-02-2005, 07:06 AM   #4
dennislbrooks
66 booster
Oreilly's Auto Parts is one place
A1 Cardone p/n 50-3537
Old 09-04-2005, 02:09 PM   #5
dennislbrooks
66 booster linkage
Well, the mounting brackets came with the 66 booster but not the linkage. Sure is fun to make this stuff--be nicer if it works. I fabricated the linkage--still need a couple of pins and finish the rod to brake arm.
Does it look close as my 67 has a fabricated/converted 79 booster?
Also 3rd pic is one of my finished rear disc mounts ---would fit bothe a 66 and 67 and others. The unknowns about the rear disc is hooking up the emergency brake cable on the 83 camaro rear calipers. Flex lines are coming and will weld a mount when it is assembled. I will pull both axles and have the flanges turnrd down to accept the 88 4wd front rotors concentric hole.
The reason I am on the 66 message board as I have a 67 and my friend has a 66 I work on. Nice to see which parts are interchangeable.
All your guys constructive input is appreciated.
Old 09-05-2005, 04:27 PM   #6
dennislbrooks
2 more pics
Finished 66 booster with a 72 mc
