Old 08-31-2005, 05:48 PM   #1
aquik72gmc350
I made GMC Headlite Diagram
I made a GMC version of the headlite w/ relays. It uses 4 relays, 2 for headlites, and 2 for high beams. Next I'm working on doing my reverse lights, and brake/turn lights.
aquik72gmc350 is offline   Reply With Quote
Old 08-31-2005, 11:42 PM   #2
Rakort
Originally Posted by aquik72gmc350
I made a GMC version of the headlite w/ relays. It uses 4 relays, 1 for each headlite, and 1 for each high beams. Let me know if you see anything wrong with it. EDIT: I'M GOING TO CHANGE SOME THINGS ON IT.
Umm, I don't see anything?
My thought is 6 realys sounds like a lot when you probably do it with two.
Rakort
Parts for Sale: Pictures
Awesome Elec. Schematic Available: Picture
Rakort is offline   Reply With Quote
Old 09-01-2005, 05:56 AM   #3
70GMCer
70GMCer's Avatar
where do you tie in the battery voltage and where is the wiring for the headlight switch? Maybe it's all there looking at me, just not labeled...........
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 09-01-2005, 08:10 AM   #4
67chevemall
67chevemall's Avatar
That is one cool avatar^^^ How much more will it go? Government mobsters suck!
force you to break the law. got weed?
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 09-01-2005, 08:55 AM   #5
sargentjones
BOLT SMASHER
sargentjones's Avatar
who knows chief. a buck 13 a liter ain't high enough. Give er time bud, sh'll hit 2 in no time
dime bags, dime bags....
get yer dime bags here:::::::::::
Jeff
73 Chevy C-10 350 4-Speed
RUST DON'T WAIT FOR NO ONE......
sargentjones is offline   Reply With Quote
Old 09-01-2005, 09:56 AM   #6
smokekiki
Mike
smokekiki's Avatar
The Brown angd the Green wires are coming from the switch,The reds are power,on this diagram
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 09-01-2005, 01:07 PM   #7
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
You have your low beam stock wire energizing you high beam relays
and vise versa. Nice schematic.
sneakysnake is offline   Reply With Quote
Old 09-01-2005, 02:01 PM   #8
68C15
blood type; Retumbo
68C15's Avatar
I see a couple of problems. the low bulbs in your diagram have the brown going to gnd. it should be fed power fromthe low relays. the green should feed both high & low bulbs. also one relay for high 7 another for low is sufficient. thats what I have on mine. using relays for the tail & brake-turn is a wasye of time & money. they dont draw enough current to warrant a relay. I agree though that the headlights being fed from a relay is a good idea. that way the light switch doesnt have to carry the load & there is more voltage at the bulbs.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 09-01-2005, 08:47 PM   #9
aquik72gmc350
68c15
I'm kinda confused now. I marked each wire with a number. Can you tell me which ones are incorrect and what to change it to? Thank-you
Old 09-01-2005, 09:43 PM   #10
sneakysnake
OK, #5 stock wire should go to coil of the low beam relay
and the #4 stock high should go to the coil of the high relay.
Othe bulbs "68c15" mentioned are color coded wrong,the BROWN should be your power wire from the low relay and BLACK should be the ground.
in other words #1 should be brown and chas grnd should be black.
On a low beam light bulb you have three prongs one is ground one is low filament and the other is a high.
A high beam bulb only has two prongs hot and ground
So on your diagram you dont really need four relays,but if you insist.LOL
then the two low relays should feed one prong on each low beam bulb.
and the high relays should feed the high bulbs plus the other prong of the low beam bulbs.
Hope that makes sense, your on the right track just need to tweek it a little
Old 09-01-2005, 10:08 PM   #11
68C15
blood type; Retumbo
68C15's Avatar
Give Me A Few Minutes & I Will Try To Rework The Diagram For You
Old 09-01-2005, 10:28 PM   #12
68C15
blood type; Retumbo
68C15's Avatar
I tried to re-do it on my computer with no luck. probably the best thing to do is call me after 8:30 Fri night (central time) & I will grab my diagram from work & walk you through it. look for a PM with my phone #.
at this moment I dont remeber if the factory is green or tan for the low beams.
PS, there is a way to do this with just one relay but it is somewhat complicated.
Old 09-01-2005, 11:43 PM   #13
sneakysnake
heres a crude version to go by,dont laugh.LOL
Old 09-02-2005, 01:28 AM   #14
Project1970
14.1 @ 96MPH
Project1970's Avatar
Yeah, also, there's no reason to need 4 relays. The brightest bulbs are what, 100W? 100W / 12V = about 8.3A per bulb. Those Bosch relays should be able to handle 30A with ease, and 16A should be no problem.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 09-02-2005, 07:37 AM   #15
68C15
blood type; Retumbo
68C15's Avatar
so just when did you pop my hood & check out my wiring?
did you see the way I converted over to an IR alternator?
<in other words sneakysnake has hit the nail on the head & saved you a call>
