Old 08-31-2005, 08:48 PM   #1
sebuttolph
Does anyone use a bedliner??
I've got a real nice '65 GMC longbed that I use occasionally for odd jobs. Owned it for 12 years and 2years ago put a '74 350, auto trans, power steering etc. Replaced the bed with planed down treated lumber. The truck was painted about that same time.
Rugs and carpets are ok to prevent scratching the bed somewhat, but a bedliner would be nice to sometimes.
Has anyone ever found a bedliner that works for our trucks?
sebuttolph is offline   Reply With Quote
Old 08-31-2005, 08:49 PM   #2
66+81
66+81's Avatar
Bedliner trap water under them and can rot out your floor, if it's a drop in.
1966 Chevy C10 longbed stepside 350/350
1981 Chevy Custom Deluxe C10 short fleet 305/350
66+81 is offline   Reply With Quote
Old 08-31-2005, 11:32 PM   #3
AesC10s
Chevy truck addict
AesC10s's Avatar
do a spray in bed liner if you do any bed liner at all. like 66+81 said drop in Bedliners trap water under them and can rot out your floor.
AesC10s is offline   Reply With Quote
Old 09-01-2005, 06:20 PM   #4
66+81
66+81's Avatar
That is the only thing that stopped me from buying a truck one time, is the bottom of the bed was rotted out.
Old 09-02-2005, 06:15 PM   #5
sebuttolph
I've thought about water catching under the liner. Wonder if its possible to cut out the bottom of a liner to expose the wood somewhat? I don't know if that would destroy the rigidty(sp?) of the total liner? The sides and wheel wells of the truck would be protected. I'm just concerned about spraying that material on the bed cause once you've done it's probably there for good!
Old 09-03-2005, 06:50 PM   #6
66+81
66+81's Avatar
They have something that you can put on it that takes the bedliner off.
Old 09-03-2005, 11:36 PM   #7
sebuttolph
Thanks for the comments. I'm going with the type suggested and stay away from the insert. It's fairly expensive to get this process done by a shop like Rhino, so I'm also checking out diy. Classic Trucks had an article on diy I found. Hope to get this done in next couple of months and will post pics of my truck. Pretty proud of it!
Old 09-05-2005, 12:44 PM   #8
66+81
66+81's Avatar
DIY should be pretty easy. A friend did it and said it was just like painting.
